このバージョンは誤った内容を含んでいる可能性があります。最新の承認済みスナップショットに切り替えてください。
必要な工具と部品
この手順は未翻訳です。 翻訳を手伝う。
この手順で使用する道具:Plastic Cards$2.99-
now you have to heat up the screen using a heat gun or hairdryer.
Use a spudger and "peel" or "slide" the spudger under the digitizer, watch out for the lcd screen). Once you're under the digitizer use a credit card or plastic cards to slide between the adhesive and the digitizer. If the adhesive is still to hard , heat again.
The guys of smartfastfix ( youtube) link : https://www.youtube.com/watch?v=QLNTUO-f... did a well job on this.
この手順は未翻訳です。 翻訳を手伝う。
use the buttons to put it in the new digitizer.
connect the flex cable to the board of the lcd screen. ( i forgot to take a picture of this , my apologies )
connect the flex cable again to the Phone ( where the plastic lid and screw was..)
put the digitizer again over the lcd screen. see that it is in the correct place.
these are the steps to follow. sometimes it is hard to see things on the pictures so again there is a good youtube movie from the guys from smartfastfix... see link in step 2 or 3 .
10 の人々がこのガイドを完成させました。
14 件のコメント
Reassembly instructions would have been nice as it's far more difficult to re-fit the screen than take it off. My advice to anyone doing this is to make sure the lcd is fitted in the correct position in the phone before sticking the screen down properly otherwise you might have to start the whole process again to realign the lcd.
Thats true. And my apologies for that. It was late that day and i did it alone so i needed both hands to do this. But your info i correct. thanks for that.
Kevin D -
Any ideas on where to buy parts? I have tried Aliexpress but ran into quality issues.
