メインコンテンツにスキップ
ring Indoor Cam Camera Replacement
必要な工具と部品
  1. ring Indoor Cam Camera Replacement, Body: 手順 1、 3の画像 1 ring Indoor Cam Camera Replacement, Body: 手順 1、 3の画像 2 ring Indoor Cam Camera Replacement, Body: 手順 1、 3の画像 3
    • Place the cam with the base facing towards you.
    • Loosen the 21.6 mm silver screw using a Phillips #1 screwdriver.
    • Remove the base from the rest of the camera.
  2. ring Indoor Cam Camera Replacement: 手順 2、 2の画像 1 ring Indoor Cam Camera Replacement: 手順 2、 2の画像 2
    • Place the cam with the top facing toward you.
    • Insert the iFixit opening pick into the crease at the top of the camera.
    • Slide the pick along the crease until you can separate the top cover of the camera from the backing.
    • Leave the pick in the crease.
  3. ring Indoor Cam Camera Replacement: 手順 3、 2の画像 1 ring Indoor Cam Camera Replacement: 手順 3、 2の画像 2
    • Place the camera on its side where the horizontal crease is facing you.
    • Insert another iFixit opening pick into the crease between the front and back portions of the camera.
  4. ring Indoor Cam Camera Replacement: 手順 4、 3の画像 1 ring Indoor Cam Camera Replacement: 手順 4、 3の画像 2 ring Indoor Cam Camera Replacement: 手順 4、 3の画像 3
    • Slide the pick along the vertical crease until you can remove the back cover of the cam, using the opening tool to pry the portions apart.
    • You may hear a popping noise when you pry it open.
  5. ring Indoor Cam Camera Replacement, Motherboard: 手順 5、 3の画像 1 ring Indoor Cam Camera Replacement, Motherboard: 手順 5、 3の画像 2 ring Indoor Cam Camera Replacement, Motherboard: 手順 5、 3の画像 3
    • Gently remove the three white leads from their sockets on the top of the motherboard.
  6. ring Indoor Cam Camera Replacement: 手順 6、 2の画像 1 ring Indoor Cam Camera Replacement: 手順 6、 2の画像 2
    • Using a Phillips #00 screwdriver, remove the two 4.7 mm black screws located in the corners of the motherboard.
    • Using a Phillips #00 screwdriver, remove the two silver 5 mm screws in the center of the motherboard.
  7. ring Indoor Cam Camera Replacement: 手順 7、 3の画像 1 ring Indoor Cam Camera Replacement: 手順 7、 3の画像 2 ring Indoor Cam Camera Replacement: 手順 7、 3の画像 3
    • Use the iFixit opening pick to pry the motherboard from the body of the camera.
  8. ring Indoor Cam Camera Replacement: 手順 8、 2の画像 1 ring Indoor Cam Camera Replacement: 手順 8、 2の画像 2
    • Detach the black wire connecting the motherboard to the body of the camera.
  9. ring Indoor Cam Camera Replacement, Camera: 手順 9、 3の画像 1 ring Indoor Cam Camera Replacement, Camera: 手順 9、 3の画像 2 ring Indoor Cam Camera Replacement, Camera: 手順 9、 3の画像 3
    • Gently turn to the motherboard's backside and remove the white leads connecting the camera to the socket in the motherboard.
    • Cautiously remove the camera.
終わりに
作成者
5人の作成者と共同で作成されました。
John Bray
メンバー登録日: 09/12/23
411 ポイント
4のガイドは作成済み
チーム
University of North Texas, Team 4-13, Harold Fall 2023 University of North Texas, Team 4-13, Harold Fall 2023人のメンバー
UNT-HAROLD-F23S4G13
4 メンバー
4のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 5
過去 30 日: 34
今までの合計 203
