メインコンテンツにスキップ
jp.ik Leap T304 Battery Replacement Replacement
必要な工具と部品
  1. jp.ik Leap T304 Battery Replacement Replacement, Rear Cover: 手順 1、 1の画像 1
    • First ensure your laptop is turned off and check if you have the necessary tools
  2. jp.ik Leap T304 Battery Replacement Replacement: 手順 2、 2の画像 1 jp.ik Leap T304 Battery Replacement Replacement: 手順 2、 2の画像 2
    • All screws are identified by circles. Pay special attention to the yellow circles, as the rubber feet hide screws.
  3. jp.ik Leap T304 Battery Replacement Replacement: 手順 3、 3の画像 1 jp.ik Leap T304 Battery Replacement Replacement: 手順 3、 3の画像 2 jp.ik Leap T304 Battery Replacement Replacement: 手順 3、 3の画像 3
    • With the opening tool, remove a rubber foot.
    • For this action you will have to exert some force, because the foot is glued with a resistant glue.
  4. jp.ik Leap T304 Battery Replacement Replacement: 手順 4、 1の画像 1
    • Remove all screws with a Philips screwdriver PH1
    • All screws are the same so don't worry about identifying them.
  5. jp.ik Leap T304 Battery Replacement Replacement: 手順 5、 3の画像 1 jp.ik Leap T304 Battery Replacement Replacement: 手順 5、 3の画像 2 jp.ik Leap T304 Battery Replacement Replacement: 手順 5、 3の画像 3
    • With the plastic tool, insert between the plastics and gently pry open.
    • With your fingers continue to force open the bottom cover on the side indicated in the figure.
    • You will feel and hear several clicks, perfectly normal, nothing is breaking. Remove the cover completely.
  6. jp.ik Leap T304 Battery Replacement Replacement: 手順 6、 1の画像 1
    • Finally, we have the laptop open and ready to replace most of its components. Look elsewhere on how to replace a component.
    • To close the laptop just follow this guide in reverse.
  7. jp.ik Leap T304 Battery Replacement Replacement, Battery Replacement or Removal: 手順 7、 1の画像 1
    • Be careful to don't touch if not necessary any electrical part of the product and insure you're properly grounding.
  8. jp.ik Leap T304 Battery Replacement Replacement: 手順 8、 1の画像 1
    • Remove mylers shown in the picture.
    • Save them for battery assembly steps
  9. jp.ik Leap T304 Battery Replacement Replacement: 手順 9、 2の画像 1 jp.ik Leap T304 Battery Replacement Replacement: 手順 9、 2の画像 2
    • Disconnect the cable marked in the figure gently, pulling it out of the connector.
  10. jp.ik Leap T304 Battery Replacement Replacement: 手順 10、 2の画像 1 jp.ik Leap T304 Battery Replacement Replacement: 手順 10、 2の画像 2
    • Gently remove the battery.
    • CAUTION!!
    • Some products may have this battery fixed with double-sided adhesive tape. In these cases, use a wide spatula to remove the battery without bending it.
    • SAFETY WARNING!
    • Never bend or puncture the battery. Danger of explosion. If you detect a swollen or damaged battery, handle it with extreme care and place it in a protective container.
終わりに
ある他の人がこのガイドを完成しました。
作成者
2人の作成者と共同で作成されました。
Nelson Oliveira
メンバー登録日: 02/03/23
741 ポイント
4のガイドは作成済み
チーム
jp.ik jp.ik人のメンバー
Business
2 メンバー
14のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 4
過去 30 日: 29
今までの合計 310
