メインコンテンツにスキップ
iVIEW-754TPC LCD Replacement
必要な工具と部品
  1. iVIEW-754TPC LCD Replacement, Rear Panel: 手順 1、 3の画像 1 iVIEW-754TPC LCD Replacement, Rear Panel: 手順 1、 3の画像 2 iVIEW-754TPC LCD Replacement, Rear Panel: 手順 1、 3の画像 3
    • Before disassembling your tablet, make sure it is powered off.
    • Use plastic opening tool to release the clips holding the device together. The clips will take a small amount of pressure to release. Once you have the plastic opening tool inserted, use a twisting action to release the clips. Start from bottom of device and work all the way around.
  2. iVIEW-754TPC LCD Replacement, Remove Battery: 手順 2、 3の画像 1 iVIEW-754TPC LCD Replacement, Remove Battery: 手順 2、 3の画像 2 iVIEW-754TPC LCD Replacement, Remove Battery: 手順 2、 3の画像 3
    • Use flat side of the spudger to get under battery and use pressure to release from glue. Do this all the way around battery until it comes off.
    • At this point do not attempt to fully remove the battery as it is still attached to the logic board.
  3. iVIEW-754TPC LCD Replacement, Camera Assembly: 手順 3、 3の画像 1 iVIEW-754TPC LCD Replacement, Camera Assembly: 手順 3、 3の画像 2 iVIEW-754TPC LCD Replacement, Camera Assembly: 手順 3、 3の画像 3
    この手順で使用する道具:
    • The camera module is located directly under the top right corner of the back cover.
    • Peel back the tape holding down the camera ribbon connector using a pair of tweezers.
    • As you peel the tape backward, the front facing camera may come out, this is not an issue.
    • If the front facing camera does not come out, gently lift it out with a pair of tweezers
  4. iVIEW-754TPC LCD Replacement, Remove Camera: 手順 4、 2の画像 1 iVIEW-754TPC LCD Replacement, Remove Camera: 手順 4、 2の画像 2
    • Use a spudger to lift flap on top of the camera ZIF adapter.
    • At this point the camera module can be easily removed with a pair of tweezers.
    • During reassembly, make sure you put the ZIF adapter snugly back into its socket and secure the flap.
  5. iVIEW-754TPC LCD Replacement, Logic Board: 手順 5、 1の画像 1
    • Remove the four 2.2mm Phillips screws holding the logic board in place. Place the screws on the iFixit magnetic project mat.
  6. iVIEW-754TPC LCD Replacement, WIFI Antenna: 手順 6、 2の画像 1 iVIEW-754TPC LCD Replacement, WIFI Antenna: 手順 6、 2の画像 2
    この手順で使用する道具:
    • Gently peel the WIFI Antenna up using a pair of tweezers.
  7. iVIEW-754TPC LCD Replacement, Disconnect LCD: 手順 7、 3の画像 1 iVIEW-754TPC LCD Replacement, Disconnect LCD: 手順 7、 3の画像 2 iVIEW-754TPC LCD Replacement, Disconnect LCD: 手順 7、 3の画像 3
    • Use a spudger to lift the flap on top of the LCD ZIF socket.
    • Gently remove the ribbon cable from the socket using a tweezers.
  8. iVIEW-754TPC LCD Replacement, Disconnect Digitizer: 手順 8、 3の画像 1 iVIEW-754TPC LCD Replacement, Disconnect Digitizer: 手順 8、 3の画像 2 iVIEW-754TPC LCD Replacement, Disconnect Digitizer: 手順 8、 3の画像 3
    • Use a spudger to lift the flap on top of the digitizer ZIF socket.
    • Gently pull the tape attached to the ribbon cable to remove the cable from its socket.
  9. iVIEW-754TPC LCD Replacement, Remove Logic Board: 手順 9、 3の画像 1 iVIEW-754TPC LCD Replacement, Remove Logic Board: 手順 9、 3の画像 2 iVIEW-754TPC LCD Replacement, Remove Logic Board: 手順 9、 3の画像 3
    • Gently slide the spudger below the logic board at the left side nearest the battery. Lift upward and away from the power button and bottom connectors.
    • The battery is still attached to the logic board. Be careful to not tear the two apart during removal.
  10. iVIEW-754TPC LCD Replacement, LCD: 手順 10、 3の画像 1 iVIEW-754TPC LCD Replacement, LCD: 手順 10、 3の画像 2 iVIEW-754TPC LCD Replacement, LCD: 手順 10、 3の画像 3
    • Insert a plastic opening tool between the LCD and digitizer on the side of the LCD with the ribbon cable. Use a second plastic opening tool to lift the LCD from the digitizer. Repeat this process on both sides of the LCD ribbon cable.
    • Fully remove the LCD from the digitizer.
終わりに
2 の人々がこのガイドを完成させました。
作成者
1人の作成者と共同作成されました。
Robert Clark
メンバー登録日: 01/21/15
1,065 ポイント
7のガイドは作成済み
チーム
USF Tampa, Team 5-4, Brown Winter 2015 USF Tampa, Team 5-4, Brown Winter 2015人のメンバー
USFT-BROWN-W15S5G4
4 メンバー
16のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 2
過去 30 日: 13
今までの合計 823
