はじめに
For this guide you will be removing rear wheels, then removing the outer shell and then replacing the motor.
パーツ
パーツは必要ありません。
  1. Remove the four exterior screws
    • Remove the four exterior screws
  2. Free shipping on all orders over $100.00 or containing a Pro Tech Toolkit!
    当社のショップを閲覧する
まとめ
Joshua
メンバー登録日: 2014年10月24日
631 ポイント
6のガイドは作成済み
チーム
UMass Dartmouth, Team 2-5, Duarte Fall 2014 UMass Dartmouth, Team 2-5, Duarte Fall 2014人のメンバー
UMASSD-DUARTE-F14S2G5
3 メンバー
7のガイドは作成済み
コメント1件
Yeah, to replace the motor just 4 screws and no parts required! Too easy, too easy to write an article that doesn’t help :( Is it just to sell a screwdriver? This would not improve your reputation. You’re wasting our time and wasting your time.
Description: Remove the 4 screws than anyone can see is a good start but did anyone been able to actualy open the body and access inside the box?
I do have an iRobot Looj 330. The body looks very similar to the other model in the range. There are 4 screws, yes but the body in 2 parts doesn’t open that easy. It’s waterproof, I believe there is a trick… Which?
Daniel B - 返信
統計データを表示:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 126
