1. Remove the four exterior screws located under controller and on the handle.
    • Remove the four exterior screws located under controller and on the handle.
    • Remove the five screw shown, and then carefully remove top plate. Electrical components are attached to top plate.
  2. Disconnect circuit board from power leads, and install new circuit board.
    • Disconnect circuit board from power leads, and install new circuit board.
  3. Free shipping on all orders over $100 or containing a Pro Tech Toolkit!
    当社のショップを閲覧する
  4. Remove the four exterior screws to gain access to inner components. These screws are located on the bottom of the controller and on the handle.
    • Remove the four exterior screws to gain access to inner components. These screws are located on the bottom of the controller and on the handle.
    • Remove the five inner screws to access the Buttons
  5. Remove top plate carefully so that none of the electrical components are damaged.
    • Remove top plate carefully so that none of the electrical components are damaged.
    • Remove broken button and insert new button into the mounting holes.
まとめ
ある他の人がこのガイドを完成しました。
Lucas Otto
メンバー登録日: 2014年11月12日
101 ポイント
1ガイドが承認済み
チーム
UMass Dartmouth, Team 2-5, Duarte Fall 2014 UMass Dartmouth, Team 2-5, Duarte Fall 2014人のメンバー
UMASSD-DUARTE-F14S2G5
3 メンバー
7のガイドは作成済み
統計データを表示:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 106
