必要な工具と部品
Flip the Roomba over so the underside is facing up.
Remove the 4 mm screw connecting the green side brush to the chassis using a Phillips #2 screwdriver.
Remove the green side brush.
Remove the five screws from the underside of the Roomba using a Phillips #2 screwdriver.
Pull the back plate up and away from the Roomba to remove it from the device.
もう少しです!
終わりに
ある他の人がこのガイドを完成しました。
