メインコンテンツにスキップ
iRobot Roomba i7 Filter Replacement
  1. iRobot Roomba i7 Filter Replacement, Filter: 手順 1、 1の画像 1
    • Flip the iRobot Roomba i7 so that the underside is facing upwards and the back is facing you.
    • On the left side at the back press the release button for the waste bin.
  2. iRobot Roomba i7 Filter Replacement: 手順 2、 1の画像 1
    • Once the bin is removed, empty any waste into a trash can.
    • Be careful while emptying. Dust may escape and cause allergies.
  3. iRobot Roomba i7 Filter Replacement: 手順 3、 1の画像 1
    • Locate the filter on the side of the bin.
    • Placing your fingers on the light grey area, pull the filter directly out of the bin.
    • If replacing the filter, follow these steps in reverse order.
  4. iRobot Roomba i7 Filter Replacement: 手順 4、 1の画像 1
    • To clean the filter, tap it on the inside of a trash can.
    • Be careful not to shake dust everywhere; it may cause allergies.
    • Do not clean the filter with any type of liquid.
終わりに
2 の人々がこのガイドを完成させました。
作成者
2人の作成者と共同で作成されました。
Ricardo Pazos Rodriguez
メンバー登録日: 01/30/20
489 ポイント
3のガイドは作成済み
3 件のコメント
Question, please! I am unable to pull the filter out of the bin. It’s stuck. Any suggestions?
Christopher Liddle - 返信
This little filter barely does it's job. even after installing a brand new one, it'll be huffing and puffing dust everywhere it goes. My old Eufy 35C did a much better job than this much more expensive Roomba.
w.vries - 返信
I replaced the filter but it’s still not working.
Ashley Marie Vazquez - 返信
コメントを追加
統計データ:
過去 24時間: 8
過去 7 日: 38
過去 30 日: 171
今までの合計 10,498
