メインコンテンツにスキップ
iRobot Roomba i7 Battery Replacement
必要な工具と部品
  1. iRobot Roomba i7 Battery Replacement, Battery: 手順 1、 3の画像 1 iRobot Roomba i7 Battery Replacement, Battery: 手順 1、 3の画像 2 iRobot Roomba i7 Battery Replacement, Battery: 手順 1、 3の画像 3
    • Warning: Swollen or cracked batteries can be hazardous to humans due to fumes or potential fire. If you feel unsafe at anytime completing this guide, put your device in a fireproof container and take it to a replacement professional.
    • Flip the iRobot Roomba i7 so that the underside is facing upwards.
    • Using a Phillips #1 screwdriver, loosen the following screws:
    • 6.27mm-screw in the center of the side brush.
    • Five 6.24mm-screws on the bottom cover.
  2. iRobot Roomba i7 Battery Replacement: 手順 2、 1の画像 1
    • Carefully remove the bottom cover.
    • If the cover is stuck or hard to remove, use a prying tool to separate it from the device.
  3. iRobot Roomba i7 Battery Replacement: 手順 3、 2の画像 1 iRobot Roomba i7 Battery Replacement: 手順 3、 2の画像 2
    • Before removing the battery, make sure that it is not hot or swollen. Swollen lithium-ion batteries release gases that are hazardous for humans.
    • Unclip the original battery and pull upwards to remove it.
    • Use a prying tool if necessary.
    • Close the Roomba app on your mobile.
    • Remove the battery from your Roomba.
    • Hold the start button for 10 seconds.
    • Reinstall the battery and charge for a full cycle. Wait for your Roomba to automatically start itself.
    • Open the mobile app and reconnect to your Roomba.
終わりに
Battery Disposal: Never dispose of old batteries in the trash. For proper disposal, take it to your local battery recycling facility. You can find one by doing a quick internet search for "battery recycling facility" and including your zip/postal code or city name in the search. Also, check out http://call2recycle.org and plug in your zip/postal code. This will show you all of the registered drop-off locations near you.
4 の人々がこのガイドを完成させました。
作成者
3人の作成者と共同で作成されました。
Ricardo Pazos Rodriguez
メンバー登録日: 01/30/20
489 ポイント
3のガイドは作成済み
5 件のコメント
Its a shame the battery is so small compared to the cavity. The run time could be greatly expanded by simply putting in a larger battery.
Reid Kersey - 返信
iFixit sells a larger battery that fills the cavity. My i7 used to take 2 charge cycles to clean the main floor of the house. Now it can do it in a single charge. iRobot Roomba i7 Battery Replacement
Justin Vanderhooft -
I bought this battery a bit ago and it would never charge :(
Gary Hulse - 返信
My j7+ says it cannot detect the battery. I have had alot of battery issues where the robot just dies where its at or doesnt charge at the base unless rebooted. Any ideas?
Rick Moore - 返信
What is charging error 19
Rick Moore - 返信
コメントを追加
統計データ:
過去 24時間: 7
過去 7 日: 89
過去 30 日: 404
今までの合計 26,253
