メインコンテンツにスキップ
iRobot Roomba i6 Cleaning Head Module Replacement
必要な工具と部品
  1. iRobot Roomba i6 Cleaning Head Module Replacement, Remove the Edge Sweeping Brush: 手順 1、 1の画像 1
    • Using your PH2 size screwdriver, remove the edge sweeping brush by unscrewing the single screw
  2. iRobot Roomba i6 Cleaning Head Module Replacement, Remove the Bottom Cover: 手順 2、 2の画像 1 iRobot Roomba i6 Cleaning Head Module Replacement, Remove the Bottom Cover: 手順 2、 2の画像 2
    • Using your PH2 screwdriver, remove all 5 of the screws.
    • The two screws up top will keep unscrewing all the way if you don't stop. Stop unscrewing as soon as you feel a noticeable change in resistance.
    • After all screws are unscrewed, gently lift the bottom cover straight up from the two points the arrows are pointing to.
  3. iRobot Roomba i6 Cleaning Head Module Replacement, Remove the Battery: 手順 3、 1の画像 1
    • It is very important to remove the battery before removing any electrically connected components, as a screwdriver could possibly cause a short in the electronics and the battery could explode.
    • Remove the battery by pushing the plastic clip up and lifting the battery out of the Roomba.
  4. iRobot Roomba i6 Cleaning Head Module Replacement, Remove the Dust Bin: 手順 4、 2の画像 1 iRobot Roomba i6 Cleaning Head Module Replacement, Remove the Dust Bin: 手順 4、 2の画像 2
    • Press the button to remove the dustbin and set it aside.
  5. iRobot Roomba i6 Cleaning Head Module Replacement, Remove the Cleaning Head Module: 手順 5、 2の画像 1 iRobot Roomba i6 Cleaning Head Module Replacement, Remove the Cleaning Head Module: 手順 5、 2の画像 2
    • Unscrew all 4 screws highlighted in red using your PH1 size screwdriver.
    • IMPORTANT Do not try to remove the screws. Just unscrew them until they are no longer biting any threads. When you remove the module, the screws will stay with the module.
    • After all screws are removed, gently lift the cleaning module by inserting your fingers into the slit highlighted in blue and lifting straight up.
終わりに
To install the replacement module, follow these instructions in reverse order.
作成者
1人の作成者と共同作成されました。
Kaden Gonzalez
メンバー登録日: 08/16/24
314 ポイント
3のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 4
過去 30 日: 16
今までの合計 322
