はじめに
This guide will help you replace the iRobot Roomba e5 battery. If your Roomba won't turn on, try to see if it will charge first. If the Roomba doesn't charge or turn on, the battery may need to be replaced.
必要な工具と部品
Flip the iRobot upside down
locate the edge sweeping brush which has a screw in the center.
Loosen the screw using a Phillips #1 screwdriver.
Loosen the five captive screws on the bottom of the Roomba using a Phillips #1 screwdriver.
もう少しです!
終わりに
