With both hands, grab the two black tabs on each end of the battery.
Pull the tabs upwards to remove the battery.
Insert the opening tool in the back of the device under the wedge.
Slowly pry the plate loose and lift it from the device.
The face plate is only designed to be removed back to front.
Loosen the screw holding the side brush in place, by using a Phillips #1 screwdriver
The screw is attached to the side brush and does not come out completely.
Lift the side brush.
Remove the three 15.8mm gold screws with a Phillips #1 screwdriver.
Lift the wheel module to remove it from the vacuum.
Remove the other wheel by repeating these steps.
Lift the two corner guards at the rear of the device by lifting and popping them out.
Pull the front sensor away slowly from the vacuum.
The cable connecting the front sensor to the Roomba is delicate, so proceed with caution.
Flip the sensor over and use a Phillips #1 screwdriver to remove the two 3.8 mm silver screws that hold the sensors to the panel.
While the two 3.8mm screws look very similar to the 6.1mm screws, the two sizes are not interchangeable, so make sure not to mix the two sizes up when reassembling the Roomba.
Once removed, pull the panel away carefully.
Remove the fourteen 6.6 mm black screws holding down the top plate using a Phillips #1 screwdriver.
Push the lip back towards the logo to remove two 6.6 mm black screws found under it using a Phillips #1 screwdriver.
Remove the nine 6.4 mm silver screws holding the motherboard to the vacuum body and the clear plastic guard using a Phillips #1 screwdriver.
Carefully remove the connector-clips that are attached to the motherboard.
Some connectors will be difficult to remove.
Using both hands, lift the motherboard connected to the camera away from the device's main motherboard.
Only lift the motherboard upwards to avoid bending the pins and causing further damage to the device's electronics.
Remove the black plastic guard that is placed in between the two computer boards
Lift the main motherboard upward and off of the vacuum.
The screw inserts are holding it in place so it will have to be lifted evenly.
Remove the motherboard from your device.
このガイドを埋め込む
サイズを選択し、以下のコードをコピーして、このガイドを小さなウィジェットとしてサイト/フォーラムに埋め込みます。
1つの手順
全ガイド
小サイズ - 600px
中サイズ - 800px
大サイズ - 1200px
プレビュー
