この修理ガイドは変更されています。最新の未承認バージョンに切り替えます。
はじめに
Replacing the motherboard is a very long process and if not done carefully it could damage the device irreparably. Proceed with caution when handling the connectors and pins that attach the motherboard to the rest of the device.
必要な工具と部品
Flip over the device and remove the two 11.5 mm screws using the Phillips #1 screwdriver.
Remove the dust bin by pressing down on the rear button on the device.
Pull the bin towards you to remove it.
21 の人々がこのガイドを完成させました。
9 件のコメント
Thank you for the replacement instructions & pictures…so helpful!
Any idea where I can purchase a roomba 980 motherboard?
LMSterling - 返信
Where can I purchase the roomba 980 motherboard?
aliexpress my friend
you don’t need to take out the modules to take out the circuit board
If you find a rectangular rubber grommet left over when you’ve finished, it goes in a slot behind the dust bin and you can reinsert it from the outside just by removing the bin first.
