この修理ガイドは変更されています。最新の未承認バージョンに切り替えます。
はじめに
This guide is in case the battery for the iRobot Roomba 980 has failed to work or is performing poorly. It may be defective, damaged during use or reached the end of its charging life-cycle. Replacing the battery is a quick and easy process that will not take much time away from your daily routine.
必要な工具と部品
Flip over the device and remove the (2)11.5mm screws using the Phillips #1 screwdriver.
3 の人々がこのガイドを完成させました。
