メインコンテンツにスキップ
iRobot Roomba 890 Charging Contacts Replacement
必要な工具と部品
  1. iRobot Roomba 890 Charging Contacts Replacement, Charging Contacts: 手順 1、 2の画像 1 iRobot Roomba 890 Charging Contacts Replacement, Charging Contacts: 手順 1、 2の画像 2
    • Use a Phillips #2 screwdriver to remove the 7.7 mm screw.
    • Remove the yellow brush head.
  2. iRobot Roomba 890 Charging Contacts Replacement: 手順 2、 1の画像 1
    • Place the Roomba facedown, with its bottom facing you.
    • Use a Phillips #2 screwdriver to remove the two 11 mm screws.
  3. iRobot Roomba 890 Charging Contacts Replacement: 手順 3、 1の画像 1
    • Remove the battery plate.
    • Remove the battery by pulling directly up on the grey pull tabs.
  4. iRobot Roomba 890 Charging Contacts Replacement: 手順 4、 2の画像 1 iRobot Roomba 890 Charging Contacts Replacement: 手順 4、 2の画像 2
    • Use a Phillips #2 screwdriver to remove the four 11 mm screws.
    • Remove the bottom plate of the Roomba.
  5. iRobot Roomba 890 Charging Contacts Replacement: 手順 5、 2の画像 1 iRobot Roomba 890 Charging Contacts Replacement: 手順 5、 2の画像 2
    • Turn Roomba face up.
    • Remove the dustbin by pressing the release button on the top side of the Roomba and pulling it straight out.
  6. iRobot Roomba 890 Charging Contacts Replacement: 手順 6、 2の画像 1 iRobot Roomba 890 Charging Contacts Replacement: 手順 6、 2の画像 2
    • Using the opening tool, remove retaining band.
    • Use the removal tool to remove the face plate as well.
    • Pry up slowly around the edges to prevent damage to the plastic components.
  7. iRobot Roomba 890 Charging Contacts Replacement: 手順 7、 3の画像 1 iRobot Roomba 890 Charging Contacts Replacement: 手順 7、 3の画像 2 iRobot Roomba 890 Charging Contacts Replacement: 手順 7、 3の画像 3
    • Use a Phillips #1 screwdriver to remove the two 9.5 mm handle screws.
    • Use a Phillips #1 screwdriver to remove the fourteen 9.5 mm top plate screws.
    • Lift the top plate off.
  8. iRobot Roomba 890 Charging Contacts Replacement: 手順 8、 2の画像 1 iRobot Roomba 890 Charging Contacts Replacement: 手順 8、 2の画像 2
    • Locate the charging contact wire connection to the motherboard.
    • Release the connector.
    • Pull gently on the white plug, not the wires themselves.
  9. iRobot Roomba 890 Charging Contacts Replacement: 手順 9、 1の画像 1
    • Use a Phillips #1 screwdriver to remove the four 9.3 mm bumper sensor screws.
  10. iRobot Roomba 890 Charging Contacts Replacement: 手順 10、 1の画像 1
    • Use a Phillips #1 screwdriver to remove the two 9.3 mm screws holding the charging contact backings in place.
    • Remove the charging contact backings.
  11. iRobot Roomba 890 Charging Contacts Replacement: 手順 11、 1の画像 1
    • Use the iFixit opening tool to gently pry down on the charging contact, on the side closest to the cliff sensor.
    • With the charging contact dislodged, pull it through the Roomba housing.
終わりに
2 の人々がこのガイドを完成させました。
作成者
1人の作成者と共同作成されました。
Devin Steiblin
メンバー登録日: 03/28/22
442 ポイント
2のガイドは作成済み
チーム
UMass Dartmouth, Team 1-3, Petersen Spring 2022 UMass Dartmouth, Team 1-3, Petersen Spring 2022人のメンバー
UMASSD-PETERSEN-S22S1G3
3 メンバー
7のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 9
過去 7 日: 24
過去 30 日: 152
今までの合計 4,048
