メインコンテンツにスキップ
iRobot Roomba 880 Bumper Sensors Replacement
必要な工具と部品
  1. iRobot Roomba 880 Bumper Sensors Replacement, Bumper Sensors: 手順 1、 2の画像 1 iRobot Roomba 880 Bumper Sensors Replacement, Bumper Sensors: 手順 1、 2の画像 2
    • Flip your Roomba over so the wheels are facing up.
    • Using a Phillips #2 screwdriver, remove the side brush and place off to the side. There will be a 10mm screw that remains in the brush.
  2. iRobot Roomba 880 Bumper Sensors Replacement: 手順 2、 3の画像 1 iRobot Roomba 880 Bumper Sensors Replacement: 手順 2、 3の画像 2 iRobot Roomba 880 Bumper Sensors Replacement: 手順 2、 3の画像 3
    • Remove the battery panel and 10mm screws with a Phillips #2 driver and then take the battery out of the device.
  3. iRobot Roomba 880 Bumper Sensors Replacement: 手順 3、 1の画像 1
    • Remove the two 10mm screws holding the back plate in place using a Phillips #2 screwdriver, and then remove the plate from the device.
  4. iRobot Roomba 880 Bumper Sensors Replacement: 手順 4、 3の画像 1 iRobot Roomba 880 Bumper Sensors Replacement: 手順 4、 3の画像 2 iRobot Roomba 880 Bumper Sensors Replacement: 手順 4、 3の画像 3
    • Using a Phillips #1 screwdriver, remove the ten 10mm screws that hold the bumper in place.
  5. iRobot Roomba 880 Bumper Sensors Replacement: 手順 5、 1の画像 1
    • Flip your Roomba over so you are looking at the face of your device.
    • Using a plastic opening tool, pry the face plate off of the Roomba.
    • While prying the the face plate off of the Roomba, do so gently. Do not force the plate off as this could result in broken pieces.
  6. iRobot Roomba 880 Bumper Sensors Replacement: 手順 6、 2の画像 1 iRobot Roomba 880 Bumper Sensors Replacement: 手順 6、 2の画像 2
    • Remove the white cover that protects the motherboard.
    • Remove the black circular face plate from your device. It is snapped in place, but you can gently pop it off.
    The white cover is held in place by a few triangular head screws in some Roomba 880’s. They do however screw in very lightly, so you might be able to remove them using a 2,2-2,4 mm flat screwdriver.
    Start removing the black face plate from the front of the robot - on the back (where the dust container button is) it is held by two “hooks” , which you need to slide backwards rather than pry upwards.
    Marcin Luchowiec - 返信
  7. iRobot Roomba 880 Bumper Sensors Replacement: 手順 7、 2の画像 1 iRobot Roomba 880 Bumper Sensors Replacement: 手順 7、 2の画像 2
    • Using a Phillips #0 screwdriver, remove the six 10mm screws holding the black panel in place.
    Some Roomba 880 models (either newer or older than the one above) have more black screws holding this black panel in place. You need to remove all 14 of them. 4 screws are hidden under the handle, so you need to remove it first in order to reach them - this can be done by pushing the handle backwards while folded - it should clip out of its hinges.
  8. iRobot Roomba 880 Bumper Sensors Replacement: 手順 8、 2の画像 1 iRobot Roomba 880 Bumper Sensors Replacement: 手順 8、 2の画像 2
    • Remove the two plastic coverings that further protect the motherboard.
  9. iRobot Roomba 880 Bumper Sensors Replacement: 手順 9、 2の画像 1 iRobot Roomba 880 Bumper Sensors Replacement: 手順 9、 2の画像 2
    • This next step will require some force as the cables are securely connected to the motherboard at this time.
    • Remove the two cables that connect the bumper and sensors from the motherboard.
    • As you can see in the photo, the cable and the location of where it goes on the motherboard are marked with their respective shapes.
    • Fully disengage the bumper, along with the skinny IR sensor track from the main part of the device.
    • The sensor track is hidden underneath the bumper, but it connected with several wires.
  10. iRobot Roomba 880 Bumper Sensors Replacement: 手順 10、 3の画像 1 iRobot Roomba 880 Bumper Sensors Replacement: 手順 10、 3の画像 2 iRobot Roomba 880 Bumper Sensors Replacement: 手順 10、 3の画像 3
    • Rotate the device 180 degrees so you are looking at the other side.
    • Remove the cables that are holding this part of the motherboard in place.
    • This might require a bit of tugging. We recommend gently wiggling the cable at the base, to help loosen the hold.
  11. iRobot Roomba 880 Bumper Sensors Replacement: 手順 11、 3の画像 1 iRobot Roomba 880 Bumper Sensors Replacement: 手順 11、 3の画像 2 iRobot Roomba 880 Bumper Sensors Replacement: 手順 11、 3の画像 3
    • Remove the 6 bumper sensors from the side of your device.
    • This will require some tugging as the sensors are securely situated in the device currently. We recommend using a spudger if they are particularly difficult.
    • You might need to cut the tape that is currently holding several sets of bumper sensor wires together. It might be helpful to tape the new sensor wires back together when putting your device back together.
    • As you can see in the third photo the cable from the bumper sensor was originally connected to the motherboard.
  12. iRobot Roomba 880 Bumper Sensors Replacement: 手順 12、 1の画像 1
    • Now you can easily snap the 6 replacement bumper sensors into the device, and begin the reassembly.
    Excellent instructions. Could include more details of disassembly instructions.
    Catherine MacGougan - 返信
終わりに
8 の人々がこのガイドを完成させました。
作成者
1人の作成者と共同作成されました。
Frances Belcher
メンバー登録日: 04/18/17
420 ポイント
2のガイドは作成済み
チーム
Cal Poly, Team S17-G4, Banghart Spring 2017 Cal Poly, Team S17-G4, Banghart Spring 2017人のメンバー
CPSU-BANGHART-S17S17G4
5 メンバー
5のガイドは作成済み
3 件のコメント
Great tutorial! I was lucky to only need to follow directions to the point of removing the bumper, just enough to reposition the metal tension springy thing in front. Obviously, I’m a neophyte and need easy to understand, illustrated content to accomplish anything mechanical. You provided everything necessary to get my Roomba back to work. Thank you!
Kip Facebook - 返信
Im a 14 year old and i had a roomba 530 with a error 9 and i fixed it i love these things there so cool it just takes a long time to fix but it was worth it!
LakeM0nst3r - 返信
just followed this guide and it was easy and replaced all the censors and it still says error 6. any ideas?
Master tyyoda - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 6
過去 30 日: 52
今までの合計 11,440
