メインコンテンツにスキップ
iRobot Roomba 880 Battery Replacement
必要な工具と部品
  1. iRobot Roomba 880 Battery Replacement, Battery: 手順 1、 2の画像 1 iRobot Roomba 880 Battery Replacement, Battery: 手順 1、 2の画像 2
    • Start with your Roomba upside down, with the wheels facing up.
    • Using a JIS driver in #1 size remove the two 15mm screws holding the battery cover in place.
  2. iRobot Roomba 880 Battery Replacement: 手順 2、 1の画像 1
    • Remove the battery cover and place it off to the side.
  3. iRobot Roomba 880 Battery Replacement: 手順 3、 2の画像 1 iRobot Roomba 880 Battery Replacement: 手順 3、 2の画像 2
    • Remove the battery using the green tabs on either side of the battery.
終わりに
ある他の人がこのガイドを完成しました。
作成者
2人の作成者と共同で作成されました。
Frances Belcher
メンバー登録日: 04/18/17
420 ポイント
2のガイドは作成済み
チーム
Cal Poly, Team S17-G4, Banghart Spring 2017 Cal Poly, Team S17-G4, Banghart Spring 2017人のメンバー
CPSU-BANGHART-S17S17G4
5 メンバー
5のガイドは作成済み
コメント 1 件
I am not trying to be negative here, but if someone needed this guide to understand that a bad battery needed to be replaced, shouldn’t you put that they would need a new battery? According to your directions, they do not need a new battery. As a result, they are going to take out their battery, and put the old one back in. The problem remains. I have never written a guide, so maybe you can only choose parts from iFixit and that is why you did not have one listed in the parts needed, but I would have thought it would have been in the directions.
Anyhow, the guide is still appreciated… please consider this only as constructive feedback to help enhance the product.
Nathan Kramer - 返信
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 5
過去 30 日: 34
今までの合計 4,686
