はじめに
This guide will teach you how to access, remove, and replace your iRobot Roomba 870 battery.
必要な工具と部品
To access the iRobot Roomba 870 battery pack, first flip the Roomba upside down.
Then find the battery pack cover that is located in the space between the caster wheel, side brush, and vacuum.
Use a Phillips #0 screwdriver to remove the two 3.5mm screws on the battery pack cover.
もう少しです!
Follow the steps in reverse order for reassembly.
終わりに
2 の人々がこのガイドを完成させました。
