メインコンテンツにスキップ
iRobot Roomba 870 Bumper Sensor Replacement
必要な工具と部品
  1. iRobot Roomba 870  Bumper Sensor Replacement, Bumper Sensor: 手順 1、 2の画像 1 iRobot Roomba 870  Bumper Sensor Replacement, Bumper Sensor: 手順 1、 2の画像 2
    • Flip the iRoomba over so that the underside is facing up.
    • Using the Phillips #0 screwdriver, remove the 4.0 mm screw in the center of the yellow side brush.
    • Remove the yellow side brush.
  2. iRobot Roomba 870  Bumper Sensor Replacement: 手順 2、 3の画像 1 iRobot Roomba 870  Bumper Sensor Replacement: 手順 2、 3の画像 2 iRobot Roomba 870  Bumper Sensor Replacement: 手順 2、 3の画像 3
    • Remove the two 3.5 mm Phillips screws that hold the battery cover onto the Roomba with a Phillips #0 screwdriver.
    • Remove the battery cover.
  3. iRobot Roomba 870  Bumper Sensor Replacement: 手順 3、 3の画像 1 iRobot Roomba 870  Bumper Sensor Replacement: 手順 3、 3の画像 2 iRobot Roomba 870  Bumper Sensor Replacement: 手順 3、 3の画像 3
    • Remove the two remaining 3.5 mm Phillips #0 screws that attach the base-plate to the bottom of the Roomba.
    • Remove the entire base-plate from the bottom of the Roomba.
  4. iRobot Roomba 870  Bumper Sensor Replacement: 手順 4、 3の画像 1 iRobot Roomba 870  Bumper Sensor Replacement: 手順 4、 3の画像 2 iRobot Roomba 870  Bumper Sensor Replacement: 手順 4、 3の画像 3
    • Remove the ten 3 mm screws that attach the bumper guard to the bumper with a Phillips #1 screwdriver.
    • Remove the bumper guard.
  5. iRobot Roomba 870  Bumper Sensor Replacement: 手順 5、 2の画像 1 iRobot Roomba 870  Bumper Sensor Replacement: 手順 5、 2の画像 2
    • Be careful when removing the bumper from the Roomba to prevent damage to the sensor wires. Remove slowly!
    • Lift up the Roomba so that its bumper is not resting on anything, and slowly separate the bumper from the device.
  6. iRobot Roomba 870  Bumper Sensor Replacement: 手順 6、 3の画像 1 iRobot Roomba 870  Bumper Sensor Replacement: 手順 6、 3の画像 2 iRobot Roomba 870  Bumper Sensor Replacement: 手順 6、 3の画像 3
    • Remove the two 3 mm screws that attach the sensor connector to the bumper/sensor with a #1 Phillips Screwdriver.
    • Carefully detach the sensor connector from the bumper and the sensor.
  7. iRobot Roomba 870  Bumper Sensor Replacement: 手順 7、 2の画像 1 iRobot Roomba 870  Bumper Sensor Replacement: 手順 7、 2の画像 2
    • The sensor is now loose on the bumper. Be careful not to rapidly move the bumper for fear of dislodging the sensor and breaking it.
    • Flip the bumper over, ensuring the sensor remains inside the sensor compartment.
    • Gently remove the bumper from the black infrared sensor.
終わりに
13 の人々がこのガイドを完成させました。
作成者
2人の作成者と共同で作成されました。
Jacob Lindberg
メンバー登録日: 04/19/17
449 ポイント
1ガイドが承認済み
チーム
Cal Poly, Team S14-G3, Banghart Spring 2017 Cal Poly, Team S14-G3, Banghart Spring 2017人のメンバー
CPSU-BANGHART-S17S14G3
4 メンバー
10のガイドは作成済み
3 件のコメント
Can not get to the plug-in area on the board to replace sensor this way. DOES NOT work this way.
jkeysgate - 返信
man kommt nicht an den Stecker. Die Anleitung bringt überhaupt nichts.
Reinhard Totzauer - 返信
Incomplete. This NEEDs to explain how to access the plug on the board.
Ed T. - 返信
コメントを追加
統計データ:
過去 24時間: 3
過去 7 日: 28
過去 30 日: 79
今までの合計 8,305
