メインコンテンツにスキップ
iRobot Roomba 770 Main Wheels Replacement
必要な工具と部品
  1. iRobot Roomba 770 Main Wheels Replacement, Battery: 手順 1、 2の画像 1 iRobot Roomba 770 Main Wheels Replacement, Battery: 手順 1、 2の画像 2
    • Flip the Roomba over so that the wheels are facing up and the dust tray is closest to you.
    • Using the J1 Phillips screwdriver, locate and unscrew the two 11mm phillips screws above the brushes on the battery panel.
    • Remove the plastic plate from the battery box.
  2. iRobot Roomba 770 Main Wheels Replacement: 手順 2、 2の画像 1 iRobot Roomba 770 Main Wheels Replacement: 手順 2、 2の画像 2
    • Locate the 2 green tabs on the left and right of the big yellow battery.
    • Grab the tabs with your hands and lift straight upward.
  3. iRobot Roomba 770 Main Wheels Replacement, Side Brush Motor: 手順 3、 1の画像 1
    • Using the J1 Philips Screwdriver, remove the 15.5 mm screw located in the center of the side brush.
    • Remove the brush by pulling upwards.
    • Do not lean directly over the brush when attempting to remove. Removing the brush requires a firm pull and may release suddenly.
  4. iRobot Roomba 770 Main Wheels Replacement: 手順 4、 2の画像 1 iRobot Roomba 770 Main Wheels Replacement: 手順 4、 2の画像 2
    • Using the J1 Philips Screwdriver, remove the two 15.5 mm screws located on the bottom of the plate covering the bottom of the roomba.
    • Lift upwards to remove the bottom plate.
  5. iRobot Roomba 770 Main Wheels Replacement: 手順 5、 2の画像 1 iRobot Roomba 770 Main Wheels Replacement: 手順 5、 2の画像 2
    • Using the J1 Philips Screwdriver, remove the two gold 15.5 mm screws located on the blue plastic module the side brush had previously been attached too.
    • Lift the blue module upwards. The module contains the motor for the side brush.
  6. iRobot Roomba 770 Main Wheels Replacement, Main Wheels: 手順 6、 2の画像 1 iRobot Roomba 770 Main Wheels Replacement, Main Wheels: 手順 6、 2の画像 2
    • Locate the three 15.5 mm screws surrounding each wheel. Use a J1 Philips screw driver to remove these.
    • The screw towards the center for each wheel may be hard to locate and may seem inaccessible. The head of your screw is long enough to reach it.
    • Use your J1 Philips screwdriver to remove these screws.
  7. iRobot Roomba 770 Main Wheels Replacement: 手順 7、 2の画像 1 iRobot Roomba 770 Main Wheels Replacement: 手順 7、 2の画像 2
    • Pull up on the wheels to remove them from the device.
終わりに
4 の人々がこのガイドを完成させました。
作成者
1人の作成者と共同作成されました。
Angelique Bonilla
メンバー登録日: 10/06/16
251 ポイント
1ガイドが承認済み
チーム
Cal Poly, Team 15-3, Livingston Fall 2016 Cal Poly, Team 15-3, Livingston Fall 2016人のメンバー
CPSU-LIVINGSTON-F16S15G3
3 メンバー
5のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 22
今までの合計 2,928
