メインコンテンツにスキップ
iRobot Roomba 655 Pet Series Front Caster Wheel Replacement
必要な工具と部品
  1. iRobot Roomba 655 Pet Series Front Caster Wheel Replacement, Removing the Side Brush: 手順 1、 2の画像 1 iRobot Roomba 655 Pet Series Front Caster Wheel Replacement, Removing the Side Brush: 手順 1、 2の画像 2
    • Flip the device over onto its back.
    • Find the side brush, and unscrew the single screw that connects to brush motor by using the Phillips head #2 screwdriver.
    • This screw doesn't completely come out of the yellow side brush.
  2. iRobot Roomba 655 Pet Series Front Caster Wheel Replacement, Removing the Back Panel: 手順 2、 2の画像 1 iRobot Roomba 655 Pet Series Front Caster Wheel Replacement, Removing the Back Panel: 手順 2、 2の画像 2
    • Using a Phillips #1 screwdriver, remove the four screws on the back panel.
    • Once the screws are loose gently pry the back plate away from the body by using the spudger tool.
    • The screws don't completely come out of the panel, but it will still come apart once unscrewed.
  3. iRobot Roomba 655 Pet Series Front Caster Wheel Replacement, Removal of Caster Wheel Housing: 手順 3、 3の画像 1 iRobot Roomba 655 Pet Series Front Caster Wheel Replacement, Removal of Caster Wheel Housing: 手順 3、 3の画像 2 iRobot Roomba 655 Pet Series Front Caster Wheel Replacement, Removal of Caster Wheel Housing: 手順 3、 3の画像 3
    • Turn the Roomba upside down, so that the vacuum and wheels are facing the ceiling.
    • Hold the caster wheel housing steady and insert the plastic spudger under the wheel housing.
    • Apply some force to pry the caster wheel straight up out of the device, and remove the caster wheel housing from the Roomba.
  4. iRobot Roomba 655 Pet Series Front Caster Wheel Replacement, Removing Wheel From Rotating Housing: 手順 4、 2の画像 1 iRobot Roomba 655 Pet Series Front Caster Wheel Replacement, Removing Wheel From Rotating Housing: 手順 4、 2の画像 2
    • Firmly hold the caster wheel housing, and remove the caster wheel from its setting.
    • Clean the caster wheel with soap and water.
    • Once the caster wheel is clean and thoroughly dried, repeat the process in reverse order to reinstall the caster wheel back to the Roomba.
終わりに
To reassemble the robot, follow these instructions in reverse order.
3 の人々がこのガイドを完成させました。
作成者
12人の作成者と共同で作成されました。
Rhett
メンバー登録日: 01/22/15
1,329 ポイント
7のガイドは作成済み
チーム
Cal Poly, Team 21-20, Maness Winter 2015 Cal Poly, Team 21-20, Maness Winter 2015人のメンバー
CPSU-MANESS-W15S21G20
4 メンバー
14のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 5
過去 30 日: 36
今までの合計 5,910
