はじめに
You will be removing the yellow side brush and the back panel of your Roomba in order to gain access to other components of your device.
必要な工具と部品
Flip the device over onto its back.
Find the side brush, and unscrew the single screw that connects to brush motor by using the Phillips head #2 screwdriver.
Using a Phillips #1 screwdriver, remove the four screws on the back panel.
Once the screws are loose gently pry the back plate away from the body by using the spudger tool.
もう少しです!
終わりに
