はじめに
You will be removing the front bumper (this runs into objects and walls) from the Roomba to gain access to the control center (display) and motherboard.
パーツ
パーツは必要ありません。
  1. Remove the ten 11mm screws that hold the front bumper to the plastic bumper protector with your Phillips #1 screwdriver. Pull the plastic bumper protector up and off of the bumper.
    • Remove the ten 11mm screws that hold the front bumper to the plastic bumper protector with your Phillips #1 screwdriver.
    • Pull the plastic bumper protector up and off of the bumper.
  2. Free shipping on all orders over $100.00 or containing a Pro Tech Toolkit!
    当社のショップを閲覧する
    Ever fixed something? That’s Genius.
    Share your repair story with #ImAGenius
    We Are All Geniuses
  3. Flip the Roomba back over, so you are viewing the top. Pull up on the front bumper to remove it. Be careful not to pull too hard because there is wiring attached to the bumper.
    • Flip the Roomba back over, so you are viewing the top.
    • Pull up on the front bumper to remove it.
      • Be careful not to pull too hard because there is wiring attached to the bumper.
    • Remove the two 7mm screws with your Phillips #1 screwdriver, holding the wire sensors in place to the front bumper.
まとめ
Rhett
メンバー登録日: 2015年01月22日
992 ポイント
7のガイドは作成済み
チーム
Cal Poly, Team 21-20, Maness Winter 2015 Cal Poly, Team 21-20, Maness Winter 2015人のメンバー
CPSU-MANESS-W15S21G20
4 メンバー
14のガイドは作成済み
統計データを表示:
過去 24時間: 0
過去 7 日: 5
過去 30 日: 39
今までの合計 891
