メインコンテンツにスキップ
iRobot Roomba 655 Pet Series Drive Wheels Replacement
必要な工具と部品
  1. iRobot Roomba 655 Pet Series Drive Wheels Replacement, Removing the Side Brush: 手順 1、 2の画像 1 iRobot Roomba 655 Pet Series Drive Wheels Replacement, Removing the Side Brush: 手順 1、 2の画像 2
    • Flip the device over onto its back.
    • Find the side brush, and unscrew the single screw that connects to brush motor by using the Phillips head #2 screwdriver.
    • This screw doesn't completely come out of the yellow side brush.
  2. iRobot Roomba 655 Pet Series Drive Wheels Replacement, Removing the Back Panel: 手順 2、 2の画像 1 iRobot Roomba 655 Pet Series Drive Wheels Replacement, Removing the Back Panel: 手順 2、 2の画像 2
    • Using a Phillips #1 screwdriver, remove the four screws on the back panel.
    • Once the screws are loose gently pry the back plate away from the body by using the spudger tool.
    • The screws don't completely come out of the panel, but it will still come apart once unscrewed.
  3. iRobot Roomba 655 Pet Series Drive Wheels Replacement, Removing the Battery: 手順 3、 3の画像 1 iRobot Roomba 655 Pet Series Drive Wheels Replacement, Removing the Battery: 手順 3、 3の画像 2 iRobot Roomba 655 Pet Series Drive Wheels Replacement, Removing the Battery: 手順 3、 3の画像 3
    • Grab the two pieces of green tape with your thumb and index finger
    • Pull up on the battery in an upwards direction to remove it
  4. iRobot Roomba 655 Pet Series Drive Wheels Replacement, Battery Contact Points: 手順 4、 2の画像 1 iRobot Roomba 655 Pet Series Drive Wheels Replacement, Battery Contact Points: 手順 4、 2の画像 2
    • These are the contact points on the Roomba for the battery
    • These are the contact points on the battery
    • If these contact points are dirty, they can be cleaned with a moist microfiber cloth (distilled water recommended)
  5. iRobot Roomba 655 Pet Series Drive Wheels Replacement, Drive Wheels: 手順 5、 3の画像 1 iRobot Roomba 655 Pet Series Drive Wheels Replacement, Drive Wheels: 手順 5、 3の画像 2 iRobot Roomba 655 Pet Series Drive Wheels Replacement, Drive Wheels: 手順 5、 3の画像 3
    • Remove the three screws with your Phillips head #1, holding the drive wheels in place
    • These three screws will stay in place and won't come out of the plastic
  6. iRobot Roomba 655 Pet Series Drive Wheels Replacement: 手順 6、 3の画像 1 iRobot Roomba 655 Pet Series Drive Wheels Replacement: 手順 6、 3の画像 2 iRobot Roomba 655 Pet Series Drive Wheels Replacement: 手順 6、 3の画像 3
    • Unscrew the actual wheel from the blue plastic holder
    • Pull apart the blue holder to completely remove the wheel
  7. iRobot Roomba 655 Pet Series Drive Wheels Replacement: 手順 7、 2の画像 1 iRobot Roomba 655 Pet Series Drive Wheels Replacement: 手順 7、 2の画像 2
    • To go further into the holder to access the programming chips you can unscrew these compartments
終わりに
ある他の人がこのガイドを完成しました。
作成者
3人の作成者と共同で作成されました。
Rhett
メンバー登録日: 01/22/15
1,329 ポイント
7のガイドは作成済み
チーム
Cal Poly, Team 21-20, Maness Winter 2015 Cal Poly, Team 21-20, Maness Winter 2015人のメンバー
CPSU-MANESS-W15S21G20
4 メンバー
14のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 19
今までの合計 2,286
