はじめに
This is when things start to get a little more tricky. Start to be more careful because everything you are dealing with is attached to your motherboard from here on out.
必要な工具と部品
Remove the dust bin by pushing on the button for the dust bin removal
Pull the dust bin out
Remove the ten 11mm screws that hold the front bumper to the plastic bumper protector with your Phillips #1 screwdriver.
Pull the plastic bumper protector up and off of the bumper.
The outside six - 10mm screws and the inside set of four - 10mm screws are the same here, use your Phillips head #2 to remove them
Use your Phillips head #0 to remove the one - 7mm bottom center screw
Use your Phillips head #2 to remove the two - 8mm screws by the handle
Push down the two release points to pull the plastic piece up
Pull the plastic piece up
Pull the silver tab, and clear tinted display off
Remove the 4 - 9mm screws holding the display with your Phillips head #0
ある他の人がこのガイドを完成しました。
