メインコンテンツにスキップ
iRobot Roomba 655 Pet Series Display Replacement
必要な工具と部品
  1. iRobot Roomba 655 Pet Series Display  Replacement, Front Face Plate: 手順 1、 2の画像 1 iRobot Roomba 655 Pet Series Display  Replacement, Front Face Plate: 手順 1、 2の画像 2
    • Remove the dust bin by pushing on the button for the dust bin removal
    • Pull the dust bin out
  2. iRobot Roomba 655 Pet Series Display  Replacement: 手順 2、 2の画像 1 iRobot Roomba 655 Pet Series Display  Replacement: 手順 2、 2の画像 2
    • Pull up on the silver handle to release the top protectant plastic
    • Remove the top plastic carefully
  3. iRobot Roomba 655 Pet Series Display  Replacement, Front Bumper: 手順 3、 2の画像 1 iRobot Roomba 655 Pet Series Display  Replacement, Front Bumper: 手順 3、 2の画像 2
    • Remove the ten 11mm screws that hold the front bumper to the plastic bumper protector with your Phillips #1 screwdriver.
    • Pull the plastic bumper protector up and off of the bumper.
  4. iRobot Roomba 655 Pet Series Display  Replacement: 手順 4、 3の画像 1 iRobot Roomba 655 Pet Series Display  Replacement: 手順 4、 3の画像 2 iRobot Roomba 655 Pet Series Display  Replacement: 手順 4、 3の画像 3
    • Flip the Roomba back over, so you are viewing the top.
    • Pull up on the front bumper to remove it.
    • Be careful not to pull too hard because there is wiring attached to the bumper.
    • Remove the two 7mm screws with your Phillips #1 screwdriver, holding the wire sensors in place to the front bumper.
  5. iRobot Roomba 655 Pet Series Display  Replacement, Internal Faceplate: 手順 5、 3の画像 1 iRobot Roomba 655 Pet Series Display  Replacement, Internal Faceplate: 手順 5、 3の画像 2 iRobot Roomba 655 Pet Series Display  Replacement, Internal Faceplate: 手順 5、 3の画像 3
    • The outside six - 10mm screws and the inside set of four - 10mm screws are the same here, use your Phillips head #2 to remove them
    • Use your Phillips head #0 to remove the one - 7mm bottom center screw
    • Use your Phillips head #2 to remove the two - 8mm screws by the handle
    • Push down the two release points to pull the plastic piece up
    • Pull the plastic piece up
  6. iRobot Roomba 655 Pet Series Display  Replacement, Display: 手順 6、 3の画像 1 iRobot Roomba 655 Pet Series Display  Replacement, Display: 手順 6、 3の画像 2 iRobot Roomba 655 Pet Series Display  Replacement, Display: 手順 6、 3の画像 3
    • Pull the silver tab, and clear tinted display off
    • Remove the 4 - 9mm screws holding the display with your Phillips head #0
  7. iRobot Roomba 655 Pet Series Display  Replacement: 手順 7、 3の画像 1 iRobot Roomba 655 Pet Series Display  Replacement: 手順 7、 3の画像 2 iRobot Roomba 655 Pet Series Display  Replacement: 手順 7、 3の画像 3
    • Remove the display
    • Remove the plastic protectant film from the motherboard
終わりに
ある他の人がこのガイドを完成しました。
作成者
3人の作成者と共同で作成されました。
Rhett
メンバー登録日: 01/22/15
1,329 ポイント
7のガイドは作成済み
チーム
Cal Poly, Team 21-20, Maness Winter 2015 Cal Poly, Team 21-20, Maness Winter 2015人のメンバー
CPSU-MANESS-W15S21G20
4 メンバー
14のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 4
今までの合計 853
