メインコンテンツにスキップ
iRobot Roomba 650 Caster Wheel Replacement
必要な工具と部品
  1. iRobot Roomba 650 Caster Wheel Replacement, Removing the Side Brush: 手順 1、 2の画像 1 iRobot Roomba 650 Caster Wheel Replacement, Removing the Side Brush: 手順 1、 2の画像 2
    • With the Roomba upside down and turned off, use the Phillip's 02 screwdriver to remove the one 3.5 mm screw from the center of the side-brush.
    • Set the screw aside and pull the brush out.
  2. iRobot Roomba 650 Caster Wheel Replacement, Bottom Panel Removal: 手順 2、 2の画像 1 iRobot Roomba 650 Caster Wheel Replacement, Bottom Panel Removal: 手順 2、 2の画像 2
    • Unscrew the four screws that hold the bottom panel using the Phillips 02 screwdriver.
    • The screws will not come out of the bottom panel. They were designed to become loose but not be removed. This prevents you from losing them, and prevents the Roomba from sucking them up if they came out during cleaning.
    • Once you are sure that all the screws have been loosened as much as possible, then lift the bottom panel up off the Roomba.
  3. iRobot Roomba 650 Caster Wheel Replacement, Caster Wheel: 手順 3、 1の画像 1
    • Begin by pulling on the caster wheel. It should pop out of its housing fairly easily.
  4. iRobot Roomba 650 Caster Wheel Replacement: 手順 4、 2の画像 1 iRobot Roomba 650 Caster Wheel Replacement: 手順 4、 2の画像 2
    • Once caster wheel is off the Roomba, push on the wheel so that it slides out of the groves it sits in.
終わりに
2 の人々がこのガイドを完成させました。
作成者
2人の作成者と共同で作成されました。
Alex Schnorr
メンバー登録日: 01/22/15
628 ポイント
3のガイドは作成済み
チーム
Cal Poly, Team 19-7, Maness Winter 2015 Cal Poly, Team 19-7, Maness Winter 2015人のメンバー
CPSU-MANESS-W15S19G7
4 メンバー
6のガイドは作成済み
3 件のコメント
Alternate instructions.
1. skip steps 1 and 2. you don't need to take the panel off to remove the caster wheel.
2. follow steps 3 and 4.
Matt Johnson - 返信
Worked for my 690 as well.
Luke Oliver - 返信
Hi, my caster wheel drops out easiy from the groves… a bit like the groves are worn out already and are no longer able to hold the wheel metal spoke in place. I would like to know if this can be fixed without resorting to buying a new wheel? (Reduce, Reuse, Recycle) Please help?
Rykel Lim - 返信
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 11
過去 30 日: 15
今までの合計 2,161
