メインコンテンツにスキップ
iRobot Roomba 650 Battery Replacement
必要な工具と部品
  1. iRobot Roomba 650 Battery Replacement, Removing the Side Brush: 手順 1、 2の画像 1 iRobot Roomba 650 Battery Replacement, Removing the Side Brush: 手順 1、 2の画像 2
    • With the Roomba upside down and turned off, use the Phillip's 02 screwdriver to remove the one 3.5 mm screw from the center of the side-brush.
    • Set the screw aside and pull the brush out.
  2. iRobot Roomba 650 Battery Replacement, Bottom Panel Removal: 手順 2、 2の画像 1 iRobot Roomba 650 Battery Replacement, Bottom Panel Removal: 手順 2、 2の画像 2
    • Unscrew the four screws that hold the bottom panel using the Phillips 02 screwdriver.
    • The screws will not come out of the bottom panel. They were designed to become loose but not be removed. This prevents you from losing them, and prevents the Roomba from sucking them up if they came out during cleaning.
    • Once you are sure that all the screws have been loosened as much as possible, then lift the bottom panel up off the Roomba.
  3. iRobot Roomba 650 Battery Replacement, Battery: 手順 3、 1の画像 1
    • Once the side brush and bottom panel are out of the way, simply grasp the battery by the two green flaps and pull it out.
    • In the unlikely event that the battery has leaked acid, avoid all contact with it and any surfaces it has affected. Wear protective gloves and wipe up any residue with a paper towel. Secure the battery in a plastic bag and dispose of it properly.
    • If you get battery acid on your skin or in your eye, flush immediately with water and seek medical attention.
終わりに
17 の人々がこのガイドを完成させました。
作成者
6人の作成者と共同で作成されました。
Charles Ward
メンバー登録日: 01/22/15
975 ポイント
3のガイドは作成済み
チーム
Cal Poly, Team 19-7, Maness Winter 2015 Cal Poly, Team 19-7, Maness Winter 2015人のメンバー
CPSU-MANESS-W15S19G7
4 メンバー
6のガイドは作成済み
コメント 1 件
We thought we were going to have to put Boohya down (our toddler named it that) so he is very happy that by simply replacing the battery we brought him back to life! Thanks! $17 well spent.
Deedra Wollert - 返信
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 16
過去 30 日: 48
今までの合計 17,798
