はじめに
The battery is an essential component of the vacuum cleaning robot. If the battery is dead, you may purchase replacement batteries from the manufacture to replace it. Here's a simple guide to replace battery of the Rooba 650. The battery is accessible after removing a couple parts from the bottom of the device.
必要な工具と部品
With the Roomba upside down and turned off, use the Phillip's 02 screwdriver to remove the one 3.5 mm screw from the center of the side-brush.
Set the screw aside and pull the brush out.
Unscrew the four screws that hold the bottom panel using the Phillips 02 screwdriver.
Once you are sure that all the screws have been loosened as much as possible, then lift the bottom panel up off the Roomba.
Once the side brush and bottom panel are out of the way, simply grasp the battery by the two green flaps and pull it out.
17 の人々がこのガイドを完成させました。
1件のガイドコメント
We thought we were going to have to put Boohya down (our toddler named it that) so he is very happy that by simply replacing the battery we brought him back to life! Thanks! $17 well spent.
