メインコンテンツにスキップ
iRobot Roomba 595 Pet Series Wheel Spring Replacement
必要な工具と部品
  1. iRobot Roomba 595 Pet Series Wheel Spring Replacement, Secondary Brush: 手順 1、 1の画像 1
    • Flip the Roomba upside down. Using the Phillips #0 screwdriver, carefully remove the 5 mm screw holding the brush in place.
  2. iRobot Roomba 595 Pet Series Wheel Spring Replacement: 手順 2、 1の画像 1
    • Gently pull the brush up and remove it from the device.
  3. iRobot Roomba 595 Pet Series Wheel Spring Replacement, Wheel Spring: 手順 3、 2の画像 1 iRobot Roomba 595 Pet Series Wheel Spring Replacement, Wheel Spring: 手順 3、 2の画像 2
    • Unscrew the four 10mm screws on the underside of the Roomba with a Phillips #1 screwdriver.
    • Remove the Roomba's external underside.
  4. iRobot Roomba 595 Pet Series Wheel Spring Replacement: 手順 4、 1の画像 1
    • Remove the 15 mm screws with the Phillips #0 screwdriver bit.
  5. iRobot Roomba 595 Pet Series Wheel Spring Replacement: 手順 5、 1の画像 1
    • Once the screws have been taken care of, the wheel component (with the spring inside) can be removed from the main assembly.
  6. iRobot Roomba 595 Pet Series Wheel Spring Replacement: 手順 6、 3の画像 1 iRobot Roomba 595 Pet Series Wheel Spring Replacement: 手順 6、 3の画像 2 iRobot Roomba 595 Pet Series Wheel Spring Replacement: 手順 6、 3の画像 3
    • Remove the two 5mm screws in the component and gently twist the casing until the spring is exposed.
    • Carefully remove the spring from the component assembly as shown
終わりに
作成者
4人の作成者と共同で作成されました。
Dale Shirley-Potopsingh
メンバー登録日: 10/02/17
446 ポイント
4のガイドは作成済み
チーム
USF Tampa, Team S10-G5, Thompson Fall 2017 USF Tampa, Team S10-G5, Thompson Fall 2017人のメンバー
USFT-THOMPSON-F17S10G5
3 メンバー
5のガイドは作成済み
4 件のコメント
My spring has fallen out and you don’t show where the spring attatches
Rebecca Hubber - 返信
Where can I get a new spring, mine is missing on the left wheel
emls23 - 返信
The bracket for the front (white and black) wheel broke. Where can I get a new one?
Kathryn Roberts - 返信
Where can I get a new spring for right wheel? Do these questions ever get answered?
KMF - 返信
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 1
過去 30 日: 16
今までの合計 1,644
