メインコンテンツにスキップ
iRobot Roomba 560 Handle Replacement
必要な工具と部品
  1. iRobot Roomba 560 Handle Replacement, Side Sweeper: 手順 1、 1の画像 1
    • Flip the Roomba upside down.
    • Unscrew the single 5 mm screw on the yellow side sweeper using the Phillips #2 driver.
  2. iRobot Roomba 560 Handle Replacement: 手順 2、 1の画像 1
    • Lift the yellow side sweeper, removing it from the device.
  3. iRobot Roomba 560 Handle Replacement, Battery: 手順 3、 1の画像 1
    • Using the Phillips #2 driver, remove the four 10 mm screws that hold the back panel in place.
  4. iRobot Roomba 560 Handle Replacement: 手順 4、 1の画像 1
    • Lift up the back panel to remove it from the device.
  5. iRobot Roomba 560 Handle Replacement: 手順 5、 2の画像 1 iRobot Roomba 560 Handle Replacement: 手順 5、 2の画像 2
    • Lift up the yellow battery by pulling up the green tabs on its side.
    • Handle the battery with care.
  6. iRobot Roomba 560 Handle Replacement, Clear Sensor Lens: 手順 6、 1の画像 1
    • Rotate the Roomba so the bumper is in front of you.
  7. iRobot Roomba 560 Handle Replacement: 手順 7、 1の画像 1
    • Using the Phillips #1 driver, remove the ten 10 mm screws on the bumper that run along the outer edge of the Roomba.
  8. iRobot Roomba 560 Handle Replacement: 手順 8、 2の画像 1 iRobot Roomba 560 Handle Replacement: 手順 8、 2の画像 2
    • Lift the thin top cover that holds the bumper in place.
  9. iRobot Roomba 560 Handle Replacement: 手順 9、 1の画像 1
    • Gently lift the device upwards from the bumper to detach these two pieces.
    • There are wires connecting the bumper to the device. Be careful while lifting the device off the bumper as to not damage these wires.
  10. iRobot Roomba 560 Handle Replacement: 手順 10、 2の画像 1 iRobot Roomba 560 Handle Replacement: 手順 10、 2の画像 2
    • Lift the bumper upwards for easier access.
    • Unscrew the two 5 mm screws that connect the red and white wires to the device using the Phillips #1 driver.
    • The sensor can be unplugged from the motherboard so the bumper isn't hanging off the Roomba.
  11. iRobot Roomba 560 Handle Replacement: 手順 11、 2の画像 1 iRobot Roomba 560 Handle Replacement: 手順 11、 2の画像 2
    • Lift the circular black panel off the lens.
    • Lift the clear lens that is on the other side of the bumper and replace it with a new lens.
  12. iRobot Roomba 560 Handle Replacement, Top Panels: 手順 12、 2の画像 1 iRobot Roomba 560 Handle Replacement, Top Panels: 手順 12、 2の画像 2
    • Turn the device over so that it is face up with the vacuum bin in front of you .
    • Press the button of the vacuum bin and pull out the bin from the device.
  13. iRobot Roomba 560 Handle Replacement: 手順 13、 1の画像 1
    • Use your hands to unhook the snaps between the silver panel from the black panel located where the vacuum bin was.
  14. iRobot Roomba 560 Handle Replacement: 手順 14、 3の画像 1 iRobot Roomba 560 Handle Replacement: 手順 14、 3の画像 2 iRobot Roomba 560 Handle Replacement: 手順 14、 3の画像 3
    • Using the plastic opening tool, go around the outer edges of the silver panel and unhook the snaps holding it in place.
    • When prying open the top panel from the inner casing, do so gently. Never "force" the top panel to snap off, or you could risk breaking pieces.
  15. iRobot Roomba 560 Handle Replacement: 手順 15、 2の画像 1 iRobot Roomba 560 Handle Replacement: 手順 15、 2の画像 2
    • Lift the black handle and use the plastic opening tool to unhook the snaps underneath it.
    • Use the same tool to pry the silver cover from the black central control board.
  16. iRobot Roomba 560 Handle Replacement: 手順 16、 3の画像 1 iRobot Roomba 560 Handle Replacement: 手順 16、 3の画像 2 iRobot Roomba 560 Handle Replacement: 手順 16、 3の画像 3
    • Lift the silver panel off of the black panel.
  17. iRobot Roomba 560 Handle Replacement: 手順 17、 1の画像 1
    • Use a Phillips #2 screwdriver to remove the following screws:
    • Two 7.5 mm-long screws at either end of the semicircular handle
    • Ten 5 mm-long screws
    • Use a Phillips #1 screwdriver to remove the 5 mm-long screw at the bottom of the control board.
  18. iRobot Roomba 560 Handle Replacement: 手順 18、 1の画像 1
    • Lift the black panel off the device.
    • This will provide access to the motherboard and black circular control panel.
  19. iRobot Roomba 560 Handle Replacement, Handle: 手順 19、 1の画像 1
    • Hold the black panel in front of you with the handle facing the other side.
    • Locate the two hinges that will be pressed in the next step.
  20. iRobot Roomba 560 Handle Replacement: 手順 20、 2の画像 1 iRobot Roomba 560 Handle Replacement: 手順 20、 2の画像 2
    • Rotate the black panel so that the handle is now facing you.
    • Insert your hands through the rectangular holes.
    • Using your index fingers, press the hinges that were located in the previous step.
  21. iRobot Roomba 560 Handle Replacement: 手順 21、 1の画像 1
    • Lift the black handle for replacement.
終わりに
3 の人々がこのガイドを完成させました。
作成者
5人の作成者と共同で作成されました。
Davis Negrete
メンバー登録日: 10/01/15
176 ポイント
1ガイドが承認済み
チーム
Cal Poly, Team 1-22, Maness Fall 2015 Cal Poly, Team 1-22, Maness Fall 2015人のメンバー
CPSU-MANESS-F15S1G22
4 メンバー
14のガイドは作成済み
コメント 1 件
Pour avoir terminé, je préciserai qu'il y a un sens pour remonter la lentille sinon le pare chocs ne coulisse pas.
De même, il n´est pas nécessaire de changer la lentille. Remettre celle d'origine (si elle n´est pas abîmée) convient très bien.
Excellent tutoriel !
Fabien-Antoine CHAPELLE - 返信
コメントを追加
統計データ:
過去 24時間: 4
過去 7 日: 13
過去 30 日: 70
今までの合計 5,783
