メインコンテンツにスキップ
iRobot Roomba 560 "Clean" Button Replacement
必要な工具と部品
  1. iRobot Roomba 560 "Clean" Button Replacement, Clear Sensor Lens: 手順 1、 1の画像 1
    • Rotate the Roomba so the bumper is in front of you.
  2. iRobot Roomba 560 "Clean" Button Replacement: 手順 2、 1の画像 1
    • Using the Phillips #1 driver, remove the ten 10 mm screws on the bumper that run along the outer edge of the Roomba.
  3. iRobot Roomba 560 "Clean" Button Replacement: 手順 3、 2の画像 1 iRobot Roomba 560 "Clean" Button Replacement: 手順 3、 2の画像 2
    • Lift the thin top cover that holds the bumper in place.
  4. iRobot Roomba 560 "Clean" Button Replacement: 手順 4、 1の画像 1
    • Gently lift the device upwards from the bumper to detach these two pieces.
    • There are wires connecting the bumper to the device. Be careful while lifting the device off the bumper as to not damage these wires.
  5. iRobot Roomba 560 "Clean" Button Replacement: 手順 5、 2の画像 1 iRobot Roomba 560 "Clean" Button Replacement: 手順 5、 2の画像 2
    • Lift the bumper upwards for easier access.
    • Unscrew the two 5 mm screws that connect the red and white wires to the device using the Phillips #1 driver.
    • The sensor can be unplugged from the motherboard so the bumper isn't hanging off the Roomba.
  6. iRobot Roomba 560 "Clean" Button Replacement: 手順 6、 2の画像 1 iRobot Roomba 560 "Clean" Button Replacement: 手順 6、 2の画像 2
    • Lift the circular black panel off the lens.
    • Lift the clear lens that is on the other side of the bumper and replace it with a new lens.
  7. iRobot Roomba 560 "Clean" Button Replacement, Top Panels: 手順 7、 2の画像 1 iRobot Roomba 560 "Clean" Button Replacement, Top Panels: 手順 7、 2の画像 2
    • Turn the device over so that it is face up with the vacuum bin in front of you .
    • Press the button of the vacuum bin and pull out the bin from the device.
  8. iRobot Roomba 560 "Clean" Button Replacement: 手順 8、 1の画像 1
    • Use your hands to unhook the snaps between the silver panel from the black panel located where the vacuum bin was.
  9. iRobot Roomba 560 "Clean" Button Replacement: 手順 9、 3の画像 1 iRobot Roomba 560 "Clean" Button Replacement: 手順 9、 3の画像 2 iRobot Roomba 560 "Clean" Button Replacement: 手順 9、 3の画像 3
    • Using the plastic opening tool, go around the outer edges of the silver panel and unhook the snaps holding it in place.
    • When prying open the top panel from the inner casing, do so gently. Never "force" the top panel to snap off, or you could risk breaking pieces.
  10. iRobot Roomba 560 "Clean" Button Replacement: 手順 10、 2の画像 1 iRobot Roomba 560 "Clean" Button Replacement: 手順 10、 2の画像 2
    • Lift the black handle and use the plastic opening tool to unhook the snaps underneath it.
    • Use the same tool to pry the silver cover from the black central control board.
  11. iRobot Roomba 560 "Clean" Button Replacement: 手順 11、 3の画像 1 iRobot Roomba 560 "Clean" Button Replacement: 手順 11、 3の画像 2 iRobot Roomba 560 "Clean" Button Replacement: 手順 11、 3の画像 3
    • Lift the silver panel off of the black panel.
  12. iRobot Roomba 560 "Clean" Button Replacement: 手順 12、 1の画像 1
    • Use a Phillips #2 screwdriver to remove the following screws:
    • Two 7.5 mm-long screws at either end of the semicircular handle
    • Ten 5 mm-long screws
    • Use a Phillips #1 screwdriver to remove the 5 mm-long screw at the bottom of the control board.
  13. iRobot Roomba 560 "Clean" Button Replacement: 手順 13、 1の画像 1
    • Lift the black panel off the device.
    • This will provide access to the motherboard and black circular control panel.
  14. iRobot Roomba 560 "Clean" Button Replacement, Side Sweeper: 手順 14、 1の画像 1
    • Flip the Roomba upside down.
    • Unscrew the single 5 mm screw on the yellow side sweeper using the Phillips #2 driver.
  15. iRobot Roomba 560 "Clean" Button Replacement: 手順 15、 1の画像 1
    • Lift the yellow side sweeper, removing it from the device.
  16. iRobot Roomba 560 "Clean" Button Replacement, Battery: 手順 16、 1の画像 1
    • Using the Phillips #2 driver, remove the four 10 mm screws that hold the back panel in place.
  17. iRobot Roomba 560 "Clean" Button Replacement: 手順 17、 1の画像 1
    • Lift up the back panel to remove it from the device.
  18. iRobot Roomba 560 "Clean" Button Replacement: 手順 18、 2の画像 1 iRobot Roomba 560 "Clean" Button Replacement: 手順 18、 2の画像 2
    • Lift up the yellow battery by pulling up the green tabs on its side.
    • Handle the battery with care.
  19. iRobot Roomba 560 "Clean" Button Replacement, "Clean" Button: 手順 19、 3の画像 1 iRobot Roomba 560 "Clean" Button Replacement, "Clean" Button: 手順 19、 3の画像 2 iRobot Roomba 560 "Clean" Button Replacement, "Clean" Button: 手順 19、 3の画像 3
    • Remove the outer silver circle, black plastic cover, and black film from the central control board in that order.
    • All of these elements are easy to remove and do not require a specialized tool.
  20. iRobot Roomba 560 "Clean" Button Replacement: 手順 20、 2の画像 1 iRobot Roomba 560 "Clean" Button Replacement: 手順 20、 2の画像 2
    • Using the Phillips #1 driver, unscrew the four 10 mm screws that surround the clean button.
    • Remove the top of the control board.
  21. iRobot Roomba 560 "Clean" Button Replacement: 手順 21、 2の画像 1 iRobot Roomba 560 "Clean" Button Replacement: 手順 21、 2の画像 2
    • Flip the control board over.
    • Using the Phillips #1 driver, unscrew the two bottommost 5 mm screws.
    • Lift off the button, and repair/replace the damaged plastic portion of the "clean" button.
終わりに
8 の人々がこのガイドを完成させました。
作成者
6人の作成者と共同で作成されました。
Naomi Hennefeld
メンバー登録日: 10/01/15
431 ポイント
1ガイドが承認済み
チーム
Cal Poly, Team 1-22, Maness Fall 2015 Cal Poly, Team 1-22, Maness Fall 2015人のメンバー
CPSU-MANESS-F15S1G22
4 メンバー
14のガイドは作成済み
2 件のコメント
This guide is also applicable to the 600 series
kjkj kjkjk - 返信
Thanks! This guide is just what I need to fix the ‘CLEAN’ button on a Roomba 652 that doesn’t work even though the ‘SPOT’ and ‘DOCK’ buttons do. I figure there’s some plastic part of the button that’s physically snapped. The robot is charging up and running as it should otherwise.
Leslie Michel - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 16
過去 30 日: 87
今までの合計 6,241
