はじめに
This guide explains how to remove the faceplate from your Roomba.
必要な工具と部品
Push on the dirt bin release button, and pull gently.
Might as well do this first, so you don’t dump dirt everywhere when flipping Roomba over.
maccentric - 返信
With a Phillips #1 screwdriver, remove the ten 12mm screws located along the bottom of the bumper.
ある他の人がこのガイドを完成しました。
コメント 1 件
If all you need off is the faceplate, you can start at step 11 and skip the 1-10. The bottom and bumper assemblies seem completely unrelated to the faceplate. I removed the dirt bin and started lifiting at the back edge, then worked around the faceplate and it just popped off with no damage.
There are 4 long friction tabs around the circumference, and no tabs at the center. Once the outer friction tabs are free, the center circle of the faceplate comes off cleanly, leaving the display panel, control buttons and the chrome-ish ring. Under the 'IR' in the IRobot logo on the faceplate is the SCI port, more plastic and a number of screws to get to the motherboard.
If all you need off is the faceplate, skip all of the screwdriver-based steps, and just remove the dirt bin(step 7) and start from step 11 at the rear.
David Forrest - 返信
