メインコンテンツにスキップ
iRobot Roomba 551 Bumper Sensor Replacement
必要な工具と部品
  1. iRobot Roomba 551 Bumper Sensor Replacement, Side Brush: 手順 1、 1の画像 1
    • Place your Roomba upside-down on a hard surface.
  2. iRobot Roomba 551 Bumper Sensor Replacement: 手順 2、 1の画像 1
    • While holding the side brush in place, use a Phillips #1 screwdriver to remove the 4.5mm screw from the center of the brush.
  3. iRobot Roomba 551 Bumper Sensor Replacement: 手順 3、 1の画像 1
    • Gently pull upwards on the brush to remove it.
  4. iRobot Roomba 551 Bumper Sensor Replacement, Bottom Plate: 手順 4、 1の画像 1
    • Rotate the Roomba upside-down so the bottom is facing towards you.
  5. iRobot Roomba 551 Bumper Sensor Replacement: 手順 5、 2の画像 1 iRobot Roomba 551 Bumper Sensor Replacement: 手順 5、 2の画像 2
    • Using a Phillips #2 screwdriver, remove the captive screws that hold the bottom plate in place.
  6. iRobot Roomba 551 Bumper Sensor Replacement: 手順 6、 1の画像 1
    • Carefully lift the bottom plate.
    • The battery is only secured in place by the bottom plate, and may fall out once the bottom plate is removed.
  7. iRobot Roomba 551 Bumper Sensor Replacement, Bumper: 手順 7、 3の画像 1 iRobot Roomba 551 Bumper Sensor Replacement, Bumper: 手順 7、 3の画像 2 iRobot Roomba 551 Bumper Sensor Replacement, Bumper: 手順 7、 3の画像 3
    • With a Phillips #1 screwdriver, remove the ten 12mm screws located along the bottom of the bumper.
  8. iRobot Roomba 551 Bumper Sensor Replacement: 手順 8、 1の画像 1
    • Lift the bottom cover and set it to the side.
  9. iRobot Roomba 551 Bumper Sensor Replacement: 手順 9、 2の画像 1 iRobot Roomba 551 Bumper Sensor Replacement: 手順 9、 2の画像 2
    • Flip the Roomba over, grasp the bumper, and gently lift to remove.
    • The battery is not secured in place once the bottom plate has been removed, and may fall out when the Roomba is turned right-side up.
  10. iRobot Roomba 551 Bumper Sensor Replacement, Bumper Sensor: 手順 10、 1の画像 1
    • Flip the Roomba so that the bottom is facing you.
  11. iRobot Roomba 551 Bumper Sensor Replacement: 手順 11、 2の画像 1 iRobot Roomba 551 Bumper Sensor Replacement: 手順 11、 2の画像 2
    • Remove the two 5mm screws located near the center of the bumper using a Phillips #1 screwdriver.
  12. iRobot Roomba 551 Bumper Sensor Replacement: 手順 12、 1の画像 1
    • Pull gently on the bottom of the sensor to remove.
  13. iRobot Roomba 551 Bumper Sensor Replacement: 手順 13、 3の画像 1 iRobot Roomba 551 Bumper Sensor Replacement: 手順 13、 3の画像 2 iRobot Roomba 551 Bumper Sensor Replacement: 手順 13、 3の画像 3
    • Flip the bumper over and lift the sensor from its compartment.
    • You are now free to replace the bumper sensor.
終わりに
4 の人々がこのガイドを完成させました。
作成者
3人の作成者と共同で作成されました。
Cody Rhoads
メンバー登録日: 01/16/14
348 ポイント
2のガイドは作成済み
チーム
Cal Poly, Team 13-14, Regan Winter 2014 Cal Poly, Team 13-14, Regan Winter 2014人のメンバー
CPSU-REGAN-W14S13G14
4 メンバー
19のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 3
過去 30 日: 4
今までの合計 4,655
