はじめに
The battery is quite simple to replace in a Roomba, and only requires removing the side brush and bottom plate before it can be accessed.
必要な工具と部品
Lift and remove the old battery by pulling the tabs on both sides.
Gently replace with a new battery.
もう少しです!
終わりに
6 の人々がこのガイドを完成させました。
If all you need off is the faceplate, skip all of the screwdriver-based steps, and just remove the dirt bin(step 7) and start from step 11 at the rear.
David Forrest - 返信
