はじめに
The back shell of the iRobot Braava Jet 240 covers the device’s water tank. Therefore, in order to remove the water tank, the back shell must first be removed. Follow this guide to replace the back shell.
必要な工具と部品
Remove the two 22.0 mm screws on the bottom-front of the robot using a Phillips #1 screwdriver.
Insert a Phillips #1 screwdriver through the screw holes.
Unscrew the two 9.7 mm screws.
もう少しです!
終わりに
