メインコンテンツにスキップ
iRULU AX106 Speaker Replacement
必要な工具と部品
  1. iRULU AX106 Speaker Replacement, iRULU AX106 Disassembly: 手順 1、 1の画像 1
    • Using a Philips head #00 screwdriver locate and remove each of the four screws located along the tall side of the iRulu.
    • There may be plastic covers protecting the screws, if this is the case take a phillips head screwdriver, and gently apply pressure on the covers until they come off.
  2. iRULU AX106 Speaker Replacement: 手順 2、 2の画像 1 iRULU AX106 Speaker Replacement: 手順 2、 2の画像 2
    • Use the opening tool to pry the screen from the case applying pressure at each of the four corners of the screen.
    • While a good deal of force is required to separate the screen from the case, make sure to separate the screen from the case at each corner before attempting to completely remove the screen. There are delicate wires that may be damaged if the screen is removed is before the corners are separated.
  3. iRULU AX106 Speaker Replacement: 手順 3、 3の画像 1 iRULU AX106 Speaker Replacement: 手順 3、 3の画像 2 iRULU AX106 Speaker Replacement: 手順 3、 3の画像 3
    • Using a pair of tweezers, gently unplug connectors A and B from the logic board.
    • Completely separate the screen and case.
  4. iRULU AX106 Speaker Replacement, Speaker: 手順 4、 1の画像 1
    この手順で使用する道具:
    Desoldering Pump
    $3.99
    購入する
    • Locate the two speakers and using the soldering iron and solder sucker carefully remove the solder that binds the two speakers down.
    • Insert the new speaker heads where the old speakers were previously.
    • Now use the soldering iron to solder the leads of the two speakers onto the logic board.
    • Be careful, the soldering iron will be extremely hot.
終わりに
作成者
4人の作成者と共同で作成されました。
Andrew Mele
メンバー登録日: 03/24/15
146 ポイント
2のガイドは作成済み
チーム
UMass Dartmouth, Team 4-7, Vijaybhaskar Spring 2015 UMass Dartmouth, Team 4-7, Vijaybhaskar Spring 2015人のメンバー
UMASSD-VIJAYBHASKAR-S15S4G7
3 メンバー
8のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 4
過去 30 日: 6
今までの合計 335
