はじめに
In this replacement guide the user will learn how to disassemble the iRULU down to the logic board, and replace the battery.
必要な工具と部品
Using a Philips head #00 screwdriver locate and remove each of the four screws located along the tall side of the iRulu.
The battery is located right above the logic board, and can be identified as a large flat black rectangle.
Use the plastic opening to scrape away the glue that is holding down the battery.
この手順で使用する道具:Desoldering Pump$3.99
You should see that the battery is connected by 2 wires, one black and one red that lead to the logic board.
Heat up a soldering iron and melt the solder that is connecting the battery to the logic board.
Completely remove the battery from the device.
Insert the new battery and re-solder the corresponding wires to their respective locations.
2 の人々がこのガイドを完成させました。
3 件のコメント
Where do you get a new battery
The batteries should be in a holder, not have to unsolder and solder. Most people do not have a soldering iron.
