はじめに
我们在2008年9月10日拆解了这部iPod。
必要な工具と部品
卸下玻璃与触摸屏总成。
Guys, for anyone trying to dissemble their ipor, be very carefull, there is on the top left of the ipod behind the benzel, a very thin cable that connects the benzel to the mother board. If you trying to remove the benzel, do not lift it untill you got the tape out, then carefully lift the benzel, and unplug the cable.
Hey, this is not easy... I've successfully broken the LCD on my ipt2g trying to fix a chip in the glass. the mistake occurred when i was initially popping it open. Ive spent the last two years of my life fixing cellphones for a radio shack and like to consider myself somewhat of an expert on using a pry tool to pop open anything. i made a noob mistake. the kind of simple ^@^^ i did on my first phones. this is simply not easy to do, applying to much force causes a violent opening, not enough and you fidget around until you slip up. go at it with purpose and a good mindset. hold it above something soft and never allow you hands to get sweaty. when you slip and break it, try to keep your cool and not kick a hole in drywall.
xKOMx... yo
U R so right, this is no experience for the faint of heart, I use 3 guitar picks, have been modified, used to use the Nokia tool (I'm Nokia level III certified) stil, I've manage to open 3 of this iPods.
GOOODDD, it's so difficult, please, be very careful, you'll find yourself replacing in the best case scenario the Digitizer.
Good luck
Beware of cracking glass opps!
computerri - 返信
For some reason the multi-touch stopped working after i started to remove the glass. should i pretend that i didn't try and mess with it and send it in for warranty repair or should i try again to take it apart? i don't know why it isn't working whether i nicked something or if somehow the glass isn't touching anymore or something silly like that.
bizzbobbからの引用:
Cool. I cracked my bezel too. Why aren't there any written instructions or warnings? $65 mistake. Ugh…
Actually, this warning is written across the top of the page:
"Teardowns provide a look inside a device and should not be used as disassembly instructions."
Floofyからの引用:
did you figure out what you did...either i have done something different or similar!
I luv this website but man what a bad set of instructions for #4. I have been repairing iPhone's for some time now and just tried my first iPod touch using these instructions....not only did I destroy the digitizer, I also destroyed the frame and the lcd! then I went to youtube and for the correct instructions. Im not blaming iFixit but a complete set of instructions would be very helpful!! oh and i still luv this site and I luv the tools I just bought off here!
chargitからの引用:
bizzbobbからの引用:
I dont understand it took me less than 45 mins to replace the digitizer and bezel and the contact was easy to connect btw i got the bezel and digitizer under $30 so look for a good seller!
露出来的LCD显示屏。
苹果给出的屏幕数据是:3.5英寸合8.89厘米(对角线),分辨率480×320像素,163ppi。
取走金属背面。
电池用两条轻质胶粘剂粘着,但很容易剥离。
how do i remove the metal backing to remove the battery? do i need to buy one of your screwdrivers?
形状颇大的橙色线缆连接WiFi天线(左上角)与主板。
图片顶部电池之上是一个金属罩。罩子之下是高通的BCM4325 WiFi及蓝牙芯片。没错,蓝牙!苹果对此没有任何公开说明。
这款蓝牙芯片组支持蓝牙2.1+EDR。还不知道苹果用的支不支持A2DP这项可连接立体声耳机的协议。
部件编号:BCM4325GKWBG CD0825 B76332 P40 SF
Qmanからの引用:
The bluetooth could be a way of tracking people or something i think someone is controlling my IPT because it will close out to the home screen in the middle of a game and that makes me mad anybody know why it does that and if it can be fixed?
That is because Ram inside the device is getting so hot that it is nearly going to overheat so the ipod cleverly shuts down the application so it can free up RAM.
technobotからの引用:
an add: restart the device to really clear the RAM.
DarkReaper - 返信
technobotからの引用:
That is because Ram inside the device is getting so hot that it is nearly going to overheat so the iPod cleverly shuts down the application so it can free up RAM.
Its not because the ram is overheating, the device doesnt generate enough heat for that to even be a factor, its because the ram is getting full.
Qmanからの引用:
Nothing about the RAM getting hot. It's just running low on memory. Apps start closing when the device has about less than 10 MB RAM available. But jailbreaking solves this, there are tweaks that allow for expanding virtual memory, e.g. iMemory Enhancer from Gumball Tech repo.
DarkReaper - 返信
你可以看到中间的dock连接座和右边的耳机孔。
pteotexzからの引用:
Do you have to dissasemble the whole board just to get to the earphone jack? I need to replace it... it looks like it requires soldering?
I have the same question.
hal
pteotexzからの引用:
Did anyone resoldered this? Is it difficult?
还是主板,不过我们把我们所认为是扬声器的东西移开了。
闪存是一颗镁光MLC芯片:MT29F64G08TAAWP
处理器是带有苹果标识的三星制ARM,和SDRAM封装在一起,如同iPhone的那样。
结束。
Where does one purchase a replacement back panel?
jgreengold - 返信
Thanks! Broke mine down too, except i used a flat screwdriver and a pocketknife! :)
not as clean as your teardown, but quite the same. Great job!
Where might one purchase a new back plate?
以下の翻訳者の皆さんにお礼を申し上げます:
94%
これらの翻訳者の方々は世界を修理する私たちのサポートをしてくれています。 あなたも貢献してみませんか?
翻訳を始める ›
3 件のコメント
Broke the screen.
probaly should of used a hair dryer
i need all the parts of ipod touch 2nd generation
hard to do really
