この翻訳は、ソースガイドの最新の更新を反映していない可能性があります。 翻訳の更新に協力してください。 または ソースガイドを参照してください。
はじめに
ガラス製フロントパネルを取り外して、お持ちのTouchの内部コンポーネントにアクセスしましょう。
必要な工具と部品
ビデオの概要
この手順は未翻訳です。 翻訳を手伝う。
The picture at left (front panel already removed) shows the locations of the metal clips (shown in red) that snap on to the plastic frame. In the next few steps, try to pry the front panel up from the gaps between these clips.
この手順は未翻訳です。 翻訳を手伝う。
Continue prying up the left edge until the top and bottom edges start to lift out of the Touch.
Once the top and bottom edges have lifted slightly out of the Touch, use the opening tool to assure the plastic surround is detached from the clips along the inside of the Touch.
デバイスを再度組み立てるには、この説明書の逆の順番で組み立ててください。
263 の人々がこのガイドを完成させました。
以下の翻訳者の皆さんにお礼を申し上げます:
33%
railgunさんは世界中で修理する私たちを助けてくれています! あなたも貢献してみませんか?
翻訳を始める ›
15 件のコメント
thanks guys! i fixed it and without you i would never do it! thaaaaankkksss!!! :D
great site!
watch out for the ribbon cable of the digitizer, its highly breakable! i had to order two new screens because i damaged the ribbon cables!
so please, really watch out with the ribbon cable!!!
Can anyone please help me I ordered a replacement screen and I put it all back to gether with out a hitch but now the middle row of Icons are not responding. Is there anything I can do to fix this issue? also the power button is not responding. anyone with suggestions are welcome thanks.
Sorry that this is literally 10 years late but, you probably damaged the ribbon cables during the opening process, you will need to order a new power button and a new display, these days it is literally impossible to find those parts so finding a new 2g on ebay is your best bet.
