はじめに
このガイドを参照して、お持ちのiPod Touchの電源/スリープボタンを取り外しましょう。
必要な工具と部品
ディスプレイガラスが飛散している場合は、さらに広がらないようにガラス上にテープを貼ってください。
透明な梱包用テープをiPodのディスプレイ上に貼り、ディスプレイ表面全体を覆います。
吸盤カップをガラス下部の中央に装着します。カップ端を、ホームボタンの中央に配置します。
カップがしっかりと固定するように、押し込んで空気を抜いてください。
Be very careful. I have bought the ifixit kit. Tried with the suction cup and it didn’t work. None of the tools actually helped. Follower the instructions carefully and still ended up with a cracked screen. I wish I could go back in time and not doing any of this. I literally just cried and have no money for a new screen.
平らなテーブル上にiPodをしっかりと固定します。
吸盤を持ち上げたら、iPodの上部に向かって引いてください。忍耐強く、一定の力で引っ張り、接着剤が剥がれてディスプレイがリアケースから浮き上がるまで作業を続けます。
接着剤を柔らかくするためにヒートガンを使用する必要があるかもしれません。(特に寒い環境下) スクリーンをこじ開けても、ピザのチーズのトッピングのように接着剤がまだ付着して外れない場合は、薄いかみそりの刃をスライドさせて接着剤を切ることができます。
Step 2.5: Recover iPod from far side of the room due to suction assisted throwing.
thanks, Apple
Did as shown, button switch works fine, when I reinstall button, it's like it won't touch the switch to engage.
What next?
I've got the same problem, managed to get the screen off, transferred the little steel plate to the new home button and put it in. The switch works fine when I press it with my finger, but it won't work with the home button??? - Did you manage to solve this problem?
Tom -
I've got the same problem. Been trying to find a solution for a few days now. Lots of people ask this question, but no one ever answers it. How did you solve it?
tirgang -
It sounds like you need to replace the home button dome switch rather than the actual home button. I'm currently searching for one myself. My customer jammed the home button and now it doesn't click. The dome switch is located on the home button ribbon cable and not on the home button.
The "home button" repair shows the physical button, but it's not actually the repair for the switch, which is what should be shown as the home button repair. The switch has a little black plastic tab that breaks off with excessive presses, and that's why the button plate cannot engage the switch when the screen is reinstalled. You will need to replace the switch, or modify it with something small enough to press the switch when the LCD is lowered.
Rene -
I also ran in to the Home button not working issue. I have not idea what changed with the button, but it would not work (from the outside) after the battery replacement & re-assembling. If you opened the iPod up, you could press the switch directly and it clicked & worked, but it seemed finicky. I ended up putting the tiniest dot of hot melt on the center of the switch (smaller than the switch 'dome', and thin too, maybe 0.6-0.7mm thick), re-assembled, and it works fine now.
Use the hair dryer or a heat gun to loosen the adhesive. This did not work with just a suction cup for me.
I also had to use a heat gun and the opening tool instead of just a suction cup to open the assembly. The rest of the guide worked really well!
When putting back together, make sure the display connector is in firm or you might get lines. And also, perform a hard reset - my power wasn't working, I took it apart and checked the power flex cable, but all it needed was a hard reset when put back together.
Suction cup and hair dryer method never worked for me. Even tried my heat gun. Finger went numb before I gave up. Used thin prying + suction cup and eventually opened it but screen cracked in the process when I was too aggressive opening it.
In hind-sight, it would have been very helpful to know that the adhesive is just in the 2 areas to either side of the home button, nothing along the edges.
Biggest complaint is the time wasted, should have just bought a replacement iPod, better return on my money/time.
The adhesive strips are only located to the left and right of the home button. Imagine two small squares of tape in each corner. Be careful heating. I used a heat gun on the lowest heat, but I think I may have overheated the area and damaged the digitizer on the bottom of the screen. I now have small green lines on that section of the screen. I too had to use a thin metal spudger to release the adhesive.
デバイス右上のプラスチックフレームとアルミ製リアケースの間に開口ツールを差し込みます。
隙間をスライドさせながら、ケースからフレームを外します。
Careful! This piece is super fragile. It really helps to understand the way the clips work. I struggled for 10 min with not a single un-clip, snapped the plastic frame in 2 places because I didn't understand the clips, and as soon as I figured out how they work the piece was off like a prom dress.
The clips are metal n shapes around the outside of the frame. They need to be pushed away from the center of the device to release the frame. You need to get something in between the plastic and clip to release, a guitar pick is probably too thick. A thin opening device would probably work but I used a razor blade. I'm not sure if these clips are on all of the newer Apple devices, but I've never encountered one before (usually work on android devices.)
I hope this helps prevent someone from having to replace the frame.
I wish I had read this comment before I broke my frame, hah! It made sense once I had the clips out, but while they were still in it was mystifying. Thankfully it won't be too big of a problem since all of the frame will still clip in, it just won't be connected.
こちら側の2つのクリップにも同じ作業を繰り返します。
プラスチックの開口ツールを、左側2番目のクリップ裏のプラスチックフレームとアルミ製リアケースの間に差し込みます。
ツールを左右に揺らしながら、ケースからクリップを外します。
Hello how are you? I don't know what happens when I go back and put everything I close and the home button doesn't work, I disarm it and check the flex and it works when I press it but with the home button it doesn't.
同様の手順で、プラスチック製フレームをリアケースに固定している最後のクリップを緩めます。
They have the exact same dimensions.
do you think if i use reolacement scren of itouch 5th gen to my itou h 6th gen this would work? i cant find screen for itouch 6th gen so im thnking to use the screen of 5th gen pls help me
画像に示されているオレンジ色ではなく黒いホームボタンアセンブリがある場合は、この手順をスキップできます。 ボタンはLCDプレートに取り付けられていないため、作業中、取り外す必要はありません。
プラスチック製開口ツールを使って、ホームボタンスイッチをLCDプレートからこじ開けます。
ホームボタン裏側の接着剤を柔らかくするために、ヒートガンまたはヘアドライヤーが必要な場合があります。 使用する際は、常に低熱設定にしてください。
If you have trouble lifting the home button switch up with the plastic opening tool, you can try using an opening pick instead.
Hi I just replaced my screen on my ipod touch 5th gen and i connect all the ribbon chords and every thing and when i connect one of the ribbons from the screen to the motherboard the motherboard starts to get hot! The screen isnt actually fully on, I wanted to make sure it turned on before I snapped it back in place. Any ideas? When I disconnect the ribbon the temp goes down. Screen is an OEM screen from Apple. I read somewhere, and i have personally have done it, that you can short the battery on the ipod touch 4th and it fixes it but im not sure on the 5th.
I have the same problem. I am going to change the battery. I let you to know if it solved the problem. Please let me know if you solve your problem. Thanks
Eddie, Did you ever fix this? I have exactly the same issue, Board gets hot and screen remains black. Although i did Hear Siri and iTunes recognises it.
You need to make sure that all the adhesive covers for the battery and the board are on so that it isn't shorting with the metal cover, this may fix some issues with the board / battery heating up a lot and display not working. I just put some electrical tape over the batter solder and screen cables so that it's all in place properly and no shorting of electric terminal points on the board.
Ben -
With some newer versions of the gen 6 iPod, it seems that removing the home button from its adhered position is not necessary. I removed mine and then realized that it was adhered to the metal of the dock, not the actual LCD shield. Just something to keep in mind, might save you some grief later if you have to re-adhere it.
ロジックボードを背面ケースに固定している1.6mm#000プラスネジを3本外します。
Hi, the MPN on that WiFi flex confirms this is not an iPod Touch 6th gen, it is 5th Gen. I am trying to source a 6th Gen WiFi Flex.
バッテリーを固定している2本の接着ストリップがあります。
iPodを裏返して、アルミ製iPodケースの裏側を温めます。バッテリーをオーバーヒートしないようご注意ください。
アルミケースを温める必要はありません。この作業中、常に熱くなった部分を指で触ることができ、熱すぎて触れなくなることはありません。
Instead of a heat gun or hair dryer, I used a rice sock (http://www.wikihow.com/Make-a-Rice-Sock) to apply heat evenly across the entire back of the case while the case still sat upright for me to work on getting the battery loose. It was a lot easier than trying to heat the back of the case, then flip the case over and work feverishly before it cooled.
I'm sure this works, but it doesn't seem like the proper way to do this. I didn't like the feeling of prying on a flimsy battery at all. That's not practical. Instead get some molybdenum wire start it underneath the corners, then wrap the ends of the wire on like 2 pencils then tape them so u dont have to wrap the wire around your fingers because it will hurt lol. then apply heat, i went about 130 degrees is what my infrared gun said. I used a geat gun on low and a good distance away. Then just work the wire down the adhesive obviously lol. This worked out very easily for me and I felt safe and more confident about what I was doing. Good luck.
If you really don’t want to remove the battery, you may lift the mainboard slightly instead and disonnect display, back camera flexes and antenna connector. Then gently pull back camera module out of the seat. This gives you enough room to connect new display and back camera flexes. Back cam module would be hanging while you connect everything that got disconnected. Screw back the mainboard and push camera module to its seat.
スパッジャーの平面側先端を使って、ディスプレイアセンブリ上のソケットから正面カメラをさっとめくります。
カメラモジュールをソケットに固定している接着剤が少量あります。しかしこれを剥がすには、それほど大きな力は必要ありません。 スパッジャーを使って、カメラモジュールの黒いプラスチックとカメラソケットの黒いプラスチックの間に挟み、それらを乖離します。
My camera ceased to work after this. Anybody have the same issue?
A reboot can sometimes work. Once the camera is seen not to be working (say it was connected after the device goes to sleep), the iPod gives up trying to show any live images from the either front or rear cameras
mark -
How do you replace the front facing camera
I have a similar issue, the rear camera doesn't work and the facing camera sometimes works but very slow...everything else works well.
Any ideas on how to fix this problem?
ヘッドフォンジャック、Lightningコネクタ、スピーカーを固定している次のネジを外します。
2.6mm#000プラスネジ3本
2.0mm#000プラスネジ2本
The screw on the right that goes into the headphone jack is a little reluctant to come out
アセンブリ全体を裏返し、ロジックボードの裏が見えるようにします。
プラスチックの開口ツールを使い、ロジックボードからデジタイザーケーブルの接続を外します。
When reassembling, the digitizer and display cable connections very easily come loose. Make sure you press them in securely then I held down the logic board with my left hand while rescrewing it down one handed with my right hand otherwise they would disengage. Took several tries to get it right.
ロジックボードアセンブリを裏返して、背面のコネクタを露出させます。
プラスチックの開口ツールの先端を使って、ロジックボード背面からアンテナコネクタを慎重にこじ開けます。
背面カメラとフレームの間にスパッジャーの平面側先端を差し込みます。
スパッジャーを慎重に捻って、カメラを解放します。
ソケットから背面カメラを持ち上げ、iPod Touchから取り外します。
デバイスを再度組み立てるには、この説明書の逆の順番で組み立ててください。
6 の人々がこのガイドを完成させました。
以下の翻訳者の皆さんにお礼を申し上げます:
100%
これらの翻訳者の方々は世界を修理する私たちのサポートをしてくれています。 あなたも貢献してみませんか?
翻訳を始める ›
Any repair guides for front camera?
ipod touch 5th generation front camera freezes then returns to rear camera. This happened after replacing battery. Any ideas? Tried hard reset & restoring. Nothing worked.
Libby - 返信
