はじめに
あなたのiPodの光沢のある側です
必要な工具と部品
視覚的にわかりやすいように、赤枠で囲った2つのクリップは、ヘッドホンジャックに最も近い位置にあります。
i don't know what genoration my ipod is...but it looks exactly like that on and it doesnt have the clips......what do i do?
https://www.ifixit.com/info/ID-your-iPod
Try that first to find what you have
Given the inherited risks of damaging the components, it would also be important to mention that the area where there are no clips is where the flat cable to the screen resides. So NO deep sticking tools in that area. It’s attractive to do because at that right side the back panel is intruded the easiest way - but dont do it.
iPodのフロントケースとリアパネルの継ぎ目、Dockコネクタの上に、iPod用開口ツールを挿入します。アルマイトのフロントケースに誤って傷をつけないようご注意ください。ツールのエッジはリアパネル側を向いている必要があります。
小型のiPod用開口ツールを、Nanoのヘッドフォンジャック側の継ぎ目に差し込みます。、ツール端がリアパネル側に向くように入れてください。
リアケースに取り付けられている2つのタブそれぞれの近くにある隙間に小さなiPod用開口ツールを押し込み、隙間をゆっくりと広げて、クリップをNanoの中央に向けて両側が乖離されるまで押し付けます。
the tool i bought because you suggested it to me got inevitably broken like it was butter made, thanks
This is virtually impossible! I have already cut myself when the stupid tool slipped trying to push in on the clips. Why on earth would anyone design something to impossible to open when they know the battery would need to be replaced at some point?
Forget the iFixit plastic tools. You need to use steel on steel. I used a heavy duty engravers knife I happened to have, to get it started. Then, a fine chisel and jeweler’s screwdrivers and LOTS of force to pry it off. I messed up the aluminum front case a bit, but I cleaned that up with sandpaper. The back case was bent a bit, but I straightened that, and after replacing the battery I fastened it back on with black electricians tape. It looks quite well, and good enough for me. I will cancel my order for a replacement back. Joe M 2/3/2018
i never needed the large tool i just needed i little flat head screwdriver
iPodの開口ツールをNanoの左上付近の隙間に差し込み、リアパネルの上部端に沿って留められた3つのクリップを外します。
すべてのタブが外れたことを確認した後、iPod本体を2つに分離します。
iPodからリアパネルが外れました。
デバイスを組み立て直すには、これらの手順を逆の順序で実行してください。
36 の人々がこのガイドを完成させました。
以下の翻訳者の皆さんにお礼を申し上げます:
100%
これらの翻訳者の方々は世界を修理する私たちのサポートをしてくれています。 あなたも貢献してみませんか?
翻訳を始める ›
2 件のコメント
but what about the model no.
its just a third-gen ipod nano they all have the same design
I found removing the back to be very difficult and had to use a mini screwdriver to complete it. While removing the back to replace the clickwheel, I not only destroyed the back, I inadvertently mangled the video cable and so I then had to replace that too.
gruntso - 返信
