はじめに
マザーボードやバッテリーはアセンブリはセット販売されてます
必要な工具と部品
視覚的にわかりやすいように、赤枠で囲った2つのクリップは、ヘッドホンジャックに最も近い位置にあります。
i don't know what genoration my ipod is...but it looks exactly like that on and it doesnt have the clips......what do i do?
https://www.ifixit.com/info/ID-your-iPod
Try that first to find what you have
Given the inherited risks of damaging the components, it would also be important to mention that the area where there are no clips is where the flat cable to the screen resides. So NO deep sticking tools in that area. It’s attractive to do because at that right side the back panel is intruded the easiest way - but dont do it.
iPodのフロントケースとリアパネルの継ぎ目、Dockコネクタの上に、iPod用開口ツールを挿入します。アルマイトのフロントケースに誤って傷をつけないようご注意ください。ツールのエッジはリアパネル側を向いている必要があります。
小型のiPod用開口ツールを、Nanoのヘッドフォンジャック側の継ぎ目に差し込みます。、ツール端がリアパネル側に向くように入れてください。
リアケースに取り付けられている2つのタブそれぞれの近くにある隙間に小さなiPod用開口ツールを押し込み、隙間をゆっくりと広げて、クリップをNanoの中央に向けて両側が乖離されるまで押し付けます。
the tool i bought because you suggested it to me got inevitably broken like it was butter made, thanks
This is virtually impossible! I have already cut myself when the stupid tool slipped trying to push in on the clips. Why on earth would anyone design something to impossible to open when they know the battery would need to be replaced at some point?
Forget the iFixit plastic tools. You need to use steel on steel. I used a heavy duty engravers knife I happened to have, to get it started. Then, a fine chisel and jeweler’s screwdrivers and LOTS of force to pry it off. I messed up the aluminum front case a bit, but I cleaned that up with sandpaper. The back case was bent a bit, but I straightened that, and after replacing the battery I fastened it back on with black electricians tape. It looks quite well, and good enough for me. I will cancel my order for a replacement back. Joe M 2/3/2018
i never needed the large tool i just needed i little flat head screwdriver
iPodの開口ツールをNanoの左上付近の隙間に差し込み、リアパネルの上部端に沿って留められた3つのクリップを外します。
すべてのタブが外れたことを確認した後、iPod本体を2つに分離します。
iPodからリアパネルが外れました。
リアケースが外れたら、Nanoの裏側は画像のような状態です。
At this stage an alternative (and more simple) procedure is to cut the battery wires between the battery and the logic board (one at a time to avoid shorts), remove the old battery, fit the new battery, strip and prepare the ends of the old cut wires, then solder the new battery to these wires again being careful not to short connections. Then sleeve or encapsulate these soldered joints (wax or blu tack will do). This makes it an easier and quicker job.
Sounds a much better idea to me.
I was just given some old parts in a box. Scored a decent router, laptop power supply and 2 ipods. Unfortunately, the newer one has half it's power connector snapped off and the other (4GB/A1236), I successfully reset via iTunes but it doesn't hold a charge! %#*@. I might just scout for an old speaker dock at a garage sale or such and put it in the bathroom or something.
次の6本のネジを外します:
1.8mmプラスネジ 1本
1.9mmプラスネジ 3本
2.4mmプラスネジ 1本
2.6mmプラスネジ 1本
If your headphone jack isn't working, note that it is possible to replace just the headphone jack here:
There are just 4 soldering points that need to be loosened, and then you can put on the new one.
I was able to remove the back cover using two think plastic guitar picks and my red cross donor card
I read some steps further back and it was recommended to NOT remove all the screws and the boards indicated in the following steps, but to go directly to replace the battery. It is no more difficult to go directly to cut the battery leads, or unsolder them. I tried to splice the new battery wires to the cut leads from the board, but it was hard working with the fine wire. I ended up clearing the top of the three battery solder-through holes, but I did not clear the holes. I soldered the battery leads directly to the top of the small round solder dots…first the white, then the black, and finally the red. I fastened the battery in-place with a piece of two-sided carpet tape. I straightened up the back and taped into place with black electricians tape. It is very delicate work, and not for a beginner…I repair family jewelry, which is valuable practice. Joe M 2/3/2018
ロジックボードをクリックホイールコネクター側(先ほど外したケーブル側)から持ち上げてフロントケースから取り出します。ロジックボードをディスプレイリボンケーブルを中心に回転させ、フロントケースの横に置いてください。
When reassembling the logic board into the case, watch out for the tiny nose of the audio jack that's facing towards the center of the device. This nose has to be inserted first, then the rest of the audio jack followed by the logic board itself.
デバイスを再度組み立てる場合は、これらの手順の逆のことを行ってください。
31 の人々がこのガイドを完成させました。
以下の翻訳者の皆さんにお礼を申し上げます:
100%
これらの翻訳者の方々は世界を修理する私たちのサポートをしてくれています。 あなたも貢献してみませんか?
翻訳を始める ›
2 件のコメント
http://www.ebay.com/itm/251624194311?ssP... some for sale on here that would be great to do this too!
I found removing the back to be very difficult and had to use a mini screwdriver to complete it. While removing the back to replace the clickwheel, I not only destroyed the back, I inadvertently mangled the video cable and so I then had to replace that too.
gruntso - 返信
