この修理ガイドは変更されています。最新の未承認バージョンに切り替えます。
はじめに
Your iPod's motherboard controls just about everything on the iPod and includes the headphone jack.
必要な工具と部品
Use a spudger to disconnect the headphone jack cable from the logic board. You need to gently pry the connector toward (or up, if you like, the connector is like LEGO® building blocks) the front of the iPod until it comes loose from the logic board.
Special hint for the reassembly: Push the connector inside until it is over the corresponding connector of the logic board. Then insert a thin tool over the connector and push it down onto the logic boards connector.
12 の人々がこのガイドを完成させました。
