この修理ガイドは変更されています。最新の未承認バージョンに切り替えます。
はじめに
Replace a cracked or faulty display.
必要な工具と部品
Remove the following 3 screws:
Two 3 mm Phillips screws near the dock connector.
One 4 mm Phillips screw along the edge of the logic board.
Insert the flat end of a spudger between the battery and the headphone jack side of the front case to pry the battery up off the adhesive securing it to the front case.
Rotate the battery out of the iPod and lay it next to the iPod. The battery is still soldered to the logic board by three wires, so don't remove it entirely.
Use a spudger to carefully pry up the adhesive holding down the edge of the display.
50 の人々がこのガイドを完成させました。
2 件のコメント
Noice! I accidentally stepped on my screen (TBF, my cat was in the way) so I decided to consult the almighty iFixit! I did have a bit of trouble removing the screen, though, as I found the adhesive too strong to pull. Therefore, I used my spudger as a lever to pull it out.
As this was my first intro into the world of DIY electronics repairing (that is to say, one that didn't have me losing every piece to it), I'm ready to see what else can come at me!
(Also, be careful not to put any fingerprints on the inside of the screen. I nearly did that, but some toilet paper and some isopropyl fixed it up.)
