メインコンテンツにスキップ
iPod Mini Hard Drive Cable Replacement
必要な工具と部品
  1. iPod Mini Hard Drive Cable Replacement, Top Bezel: 手順 1、 1の画像 1
    • Before opening your iPod, ensure that the hold switch is in the locked position.
  2. iPod Mini Hard Drive Cable Replacement: 手順 2、 1の画像 1
    この手順で使用する道具:
    Jimmy
    $7.95
    購入する
    • Carefully insert a small flathead screwdriver or Jimmy in the seam between the metal casing and white plastic top. Use the screwdriver to pry up the white plastic top bezel. Be careful not to damage the soft plastic with your screwdriver.
    • The top bezel is held on with an adhesive, so it may be necessary to pry up in several different locations to free the part.
    • To make this job easier, heat up the adhesive with a hairdryer on low heat for a few seconds.
  3. iPod Mini Hard Drive Cable Replacement: 手順 3、 1の画像 1
    • Lift the top bezel off of the iPod.
  4. iPod Mini Hard Drive Cable Replacement, Bottom Bezel: 手順 4、 1の画像 1
    この手順で使用する道具:
    Jimmy
    $7.95
    購入する
    • Carefully insert a small flathead screwdriver or Jimmy in the seam between the metal casing and white plastic bottom Use the screwdriver to pry up the white plastic bottom bezel. Be careful not to damage the soft plastic with your screwdriver.
  5. iPod Mini Hard Drive Cable Replacement: 手順 5、 1の画像 1
    • A small pair of snap ring pliers is the easiest tool to remove the metal retaining bracket.
    • You can also use a flathead screwdriver to pry out the metal retaining bracket beneath the bottom bezel as shown. You can free the bracket by first pushing in the metal arms on the corners and then lifting the bracket.
  6. iPod Mini Hard Drive Cable Replacement: 手順 6、 1の画像 1
    • Lift the metal retaining bracket out of the iPod.
  7. iPod Mini Hard Drive Cable Replacement, Hard Drive: 手順 7、 1の画像 1
    • Use a spudger or the tip of your finger to carefully disconnect the orange click wheel ribbon from the logic board.
  8. iPod Mini Hard Drive Cable Replacement: 手順 8、 1の画像 1
    • Remove the two #00 Phillips screws securing the headphone jack to the casing.
  9. iPod Mini Hard Drive Cable Replacement: 手順 9、 1の画像 1
    • Carefully slide the iPod out of its casing by pushing on the logic board near the bottom edge of the click wheel.
    • Do not pull on the headphone jack board at the top of the iPod, as the connector to the logic board is fragile.
  10. iPod Mini Hard Drive Cable Replacement: 手順 10、 1の画像 1
    • After pushing the logic board out sufficiently, gently grasp the logic board on either side of the display, and continue to slide the iPod out of its casing.
  11. iPod Mini Hard Drive Cable Replacement: 手順 11、 1の画像 1
    • Lift the battery off of the logic board and lay it to the side of the iPod.
  12. iPod Mini Hard Drive Cable Replacement: 手順 12、 1の画像 1
    • Use a spudger or the tip of your finger to carefully disconect the orange hard drive ribbon from the logic board.
  13. iPod Mini Hard Drive Cable Replacement: 手順 13、 1の画像 1
    • Lift the hard drive out of the iPod.
  14. iPod Mini Hard Drive Cable Replacement, Hard Drive Cable: 手順 14、 1の画像 1
    • Peel back the black tape securing the two blue bumpers to the hard drive near the orange ribbon cable.
  15. iPod Mini Hard Drive Cable Replacement: 手順 15、 1の画像 1
    • Slide the two blue bumpers off the corners of the hard drive. There is no need to remove these bumpers entirely.
  16. iPod Mini Hard Drive Cable Replacement: 手順 16、 1の画像 1
    • Carefully disconnect the orange hard drive ribbon cable from the hard drive. Be sure to apply even pressure while pulling to prevent any bent pins.
    • If the cable doesn't come free easily, you may be able to free it by gently rocking the ribbon cable back and forth.
終わりに
13 の人々がこのガイドを完成させました。
作成者
1人の作成者と共同作成されました。
iRobot
メンバー登録日: 09/24/09
1 ポイント
636のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 3
過去 7 日: 11
過去 30 日: 68
今までの合計 17,702
