メインコンテンツにスキップ
iPod Classicのディスプレイの交換
必要な工具と部品
  1. iPod Classicのディスプレイの交換, ハードドライブ: 手順 1、 1の画像 1
    • Appleは、主要なコンポーネントを破壊せずに分解することが非常に難しいiPodを設計しました。金属製のフェイスプレート、金属製のバッキング、そしてケースを一緒に保持する13個(そうです、13個です)の金属製クリップのため、これは分解するのが最も難しいiPodの1つです。
    • iPodを現在の状態以上に著しく損傷させる可能性があるという警告と注意を払って作業を進めてください。また、iPodを開くときに破損しやすいので、取り付けの際には、プラスチック製の開封工具を数組余分に用意しておくとよいでしょう。それでは頑張りましょう!
    • iPodを開く前に、ホールドスイッチがロックされていることを確認してください。
    If you're meticulous, the job can perfectly be done, without any of the recommended tools. I hadn't the time to order them, so I opened my iPod with the large blade of my Victorinox swiss army knife. By just following the instruction I succeeded in releasing all of the metal tabs all around the iPod, and didn't damage any of them. You can clearly hear them "declipsing". I think the blade of the Victorinox is thiner than the putty knife, the only thing you have to take care of, is not to cut the black or silver painting of the front of the case, but if you are used to cut with a knife, you should succeed. Just be aware that it is however a difficult job !
    jcfsystems - 返信
    Thank you for these instructions - my dead iPod classic (that died whilst attached to an ipod dock during a heavy thunderstorm which took out the dock too) is now working again. Opening the case took me 40 minutes and 7 plastic case openers not to mention very sore hands but the rest of the process worked fine. thanks again
    Stuart Hutchesson - 返信
    Opened it up with MANY super thin nylon guitar picks in less than a minute starting from the two tabs on the bottom - I used the putty knife in my shop for wood filler and patching walls :)
    cmguitar - 返信
    Appreciated the earlier comment about using guitar picks. It is waaaaaay easier to open the iPod with guitar picks. It still requires patience sometimes, but no noticeable damage to the iPod. Went to the local music store, they stocked Fender picks. Fender "Thin" work best for me for starters, but sometimes Fender "Medium" are needed. (Go to your local music store-- very cheap!) I have opened (and repaired successfully!) four different iPods just using guitar picks.
    Novice iPod Repair Guy - 返信
  2. iPod Classicのディスプレイの交換: 手順 2、 1の画像 1
    • このiPodを開けるのは難しいです。iPodを開けるまで何回かかってもやる気をなくさないでください。注意すべきことは、プラスチック製オープニングツールをiPodに入れているときのツールの先端の角度です。
    • プラスチック製オープニングツールをiPodの表面と裏面の間の継ぎ目に差し込みます。
    I have with luck (several times) used the metal spudger to create a small initial gap.
    But be careful, it's easy to severely scratch the iPod.
    rousp - 返信
    right here, you should insert a picture of the little clips on the rails inside the back of the ipod, so that we can visualise what we're trying to undo, & get a better idea of which way to bend, which way NOT to bend the tools.
    duncanrmi - 返信
    Good point! There is such a picture showing the location of at least four (4) clips on each side of the case here:
    https://d3nevzfk7ii3be.cloudfront.net/ig...
    in the Step 4 of the “iPod Classic Teardown”: iPod Classic Teardown
    As mentioned below by Kevin M there are 3 more (1 on top and 2 on the bottom sides).
    LDS -
    Actually it’s a wayyyyyyy easier using the iFlash opening tool and following the pdf of this guy (youtube link)
    Bastien Arata - 返信
    Actually it’s wayyyyyy easier using this tool as mentioned by this awesome guy on his video.
    Bastien Arata - 返信
    That video is excellent. He has a PDF you print which is the same size as the iPod so you know exactly where the 11 clips are (1 on top, 2 on bottom, and 4 more along each side).
    Kevin Moorman - 返信
    Appreciated the earlier comment about using guitar picks. It is very easy to open the iPod with guitar picks. It still requires patience sometimes, but no noticeable damage to the iPod. Went to the local music store, they stocked Fender picks. Fender "Thin" work best for me for starters, but sometimes Fender "Medium" are needed. (Go to your local music store-- very cheap!) I have opened (and repaired successfully!) four different iPods just using guitar picks.
  3. iPod Classicのディスプレイの交換: 手順 3、 1の画像 1
    • iPodの表面と裏面の間の継ぎ目に、もう一つのプラスチック製開口ツールを差し込みます。そして、2つのツール間に少なくとも4cm弱程度のスペースを空け、ツールをそのままの状態にします。
  4. iPod Classicのディスプレイの交換: 手順 4、 1の画像 1
    • パテナイフを2つの開口部ツールの継ぎ目に、慎重に斜めの角度で3mm程度挿入します。
    • リアパネルの内側には細い金属製のレールが通っているので、パテナイフを入れるときには十分注意してください。
    • パテナイフでリアパネルの外縁を外せたら、パテナイフを垂直にして、慎重に(かつ、時間をかけてしっかりと)パテナイフを開口部に差し込んでいるツールと本体の隙間に真っ直ぐ差し込みます。
    I tried this on the first iPod I was trying to fix. This method really messes up the sides of the iPod. Go back and read earlier comments about using guitar picks or other tools!
  5. iPod Classicのディスプレイの交換: 手順 5、 1の画像 1
    • パテナイフの後ろのリアパネルを指で押しながら、変形しないようにします。画像のようにパテナイフをゆっくりと曲げて、iPod側面のメタル製タブの大部分を外します。
    • この方法は、リアパネルを全く曲げないようにするのではなく、後で簡単に復元できるように有利な方法で曲げるというものです。そのため、リアパネル側面を曲げる際には、曲面を押し出すのではなく、リアパネルの外縁をiPodから離すようにします。また、この方法でできるだけ多くの側面クリップを外すことができます。
  6. iPod Classicのディスプレイの交換: 手順 6、 1の画像 1
    • iPodからパテナイフを外して、前の手順と同じように小刻みにスライドさせながら、iPodのコーナーに付近で再び挿入します。
    • 可能な限り、リアパネルの角を曲げないでください。
  7. iPod Classicのディスプレイの交換: 手順 7、 1の画像 1
    • プラスチック製開口ツールを、ヘッドフォンジャック付近のiPodの前面と背面の継ぎ目に差し込みます。
    • 慎重にパテナイフを下向きに曲げて、開口ツール用の隙間を作る方が簡単に見えるかもしれませんが、リアパネルの角を曲げないようにしてください。
  8. iPod Classicのディスプレイの交換: 手順 8、 1の画像 1
    • ディスプレイ中央付近で、プラスチック製開口ツールで作った隙間に、メタル製スパッジャーをゆっくりと差し込みます。
    • ここでリアパネルに目立った凹凸を作ってしまうと修理が難しくなります。リアパネルを外側に曲げるのではなく、メタル製スパッジャーをリアパネルの端が支点になるようにしてタブをこじ開けてください。
    • メタル製スパッジャーを使って、iPod上部にある1つのクリップを外します。
  9. iPod Classicのディスプレイの交換: 手順 9、 1の画像 1
    • 反対側の上部コーナー付近で、プラスチック製の開口部用ツールをiPodの前面と背面の間の縫い目に挿入します。
  10. iPod Classicのディスプレイの交換: 手順 10、 1の画像 1
    • 反対側では、iPodの前面と背面の間のシーム部分にプラスチック製開口部ツールを挿入します。
    • 隙間を作るためには、上部コーナーに差し込まれているツール先端に角度をつけた方が効果的です。
  11. iPod Classicのディスプレイの交換: 手順 11、 1の画像 1
    • 上部コーナーから開口ツールを取り出し、iPodの表面と裏面の間の継ぎ目に差し込みます。その際、2つのツール間に少なくとも約3.8cmのスペースを空けます(反対側と同じように)。
  12. iPod Classicのディスプレイの交換: 手順 12、 1の画像 1
    • 斜めの角度にして、パテナイフを2つの開口ツールの継ぎ目に3mm程度ほど差し込みます。
    • また、リアパネル内側には細いメタル製のレールが通っているので、パテナイフを入れる際には細心の注意が必要です。
    • パテナイフでリアパネルの外縁が外れたら、パテナイフが垂直になるように角度をつけ、慎重に(しかし確実に)、プラスチック製開口ツールの隙間を通して、iPodの中にまっすぐ差し込みます。
    • パテナイフの後ろのリアパネルを指で押して、曲がらないように固定します。パテナイフを少しだけ曲げて、iPodのこちら側のメタルタブの全体を外します。
  13. iPod Classicのディスプレイの交換: 手順 13、 1の画像 1
    • コーナー付近のメタル製クリップは、フロントパネルを頑強に固定しているため悪名高いです。iPodを開口するために、これらのクリップを外さなければなりません。
    • 頑強なメタル製クリップ付近のエリアに、メタル製スパッジャーを注意深く差し込みます。
  14. iPod Classicのディスプレイの交換: 手順 14、 1の画像 1
    • メタル製スパジャーをゆっくりと動かして、リアパネルの中に底まで差し込みます。
  15. iPod Classicのディスプレイの交換: 手順 15、 1の画像 1
    • ゆっくりとフロントパネルからクリップを外し始めます。
    • ここでリアパネル上に目立った凹凸を作ってしまうと修理が難しくなります。タブをこじ開けるときは、リアパネルを外側に曲げるのではなく、金属製のスパッジャーがリアパネルの端を支点になるようにしてください。
  16. iPod Classicのディスプレイの交換: 手順 16、 1の画像 1
    • 続けて、メタル製クリップが解放されるまで、メタルスパッジャーを使って、フロントパネルを押し上げます。
  17. iPod Classicのディスプレイの交換: 手順 17、 1の画像 1
    • リアパネルをiPod本体に接続している2本のリボンケーブルがあります。次の手順では、これらのリボンケーブルにダメージを与えないようご注意ください。
    • 片手でフロントパネルアセンブリを掴み、もう片方の手でリアパネルを掴みます。
    • 深呼吸しましょう!
    • 2つのコンポーネントを同時に接続しているリボンケーブルにダメージを与えないよう細心の注意を払いながら、フロントパネルの上部とリアパネルの上部を互いに(ヒンジとしてのiPodの底部を考えてください)引き離して、リアパネル上の残りのクリップを慎重に外します。
  18. iPod Classicのディスプレイの交換: 手順 18、 1の画像 1
    • スパッジャーを使って、オレンジ色のバッテリーリボンを固定しているコネクタを上部にスライドします。ケーブルを解放するには、ロッキングバーを約2mm持ち上げるだけで十分です。
    • コネクタからオンレジ色のバッテリーリボンをスライドして、取り出します。
    If the small battery black/white connector pumps out of the ipod when you are trying to unplug the cable...REMEMBER the "U" black shape is meant to be just in the same direction as the blue plastic "U" beside it. If you plug it back in the wrong way it will display "Charging please wait..." forever!.
    riverate - 返信
    How did you get the black battery piece to stay in after it popped out?
    Katrina Frantz -
    I knocked this little bit out too! Any tips to get it back in? Soldering?
    David Ewing -
    This step is what ultimately destroyed my iPod. A caution to be very careful would be good.
    I got the whole black white thing disconnected from the pins. After a lot of struggle I was able to get it back in, but I couldn’t get the black locking part to go up on its own. after many tries and some tries to get it in when the black thing is closed, i tore out the pins that were connected to the panel. can’t get it back on so it isn’t connected to the battery…
    Now i have a perfect iPod with a new harddrive but I can’t use it.
    Please add a red caution sentence because I’m pretty sure that if i had known what I had to do I would’ve been more careful and I would now have a functioning iPod.
    Nonetheless, great guide! without this I wouldn’t even have tried and the harddisk came from another broken down iPod classic so it’s not that I lost money.
    stef.kuypers - 返信
    I got the whole battery clamp connector (black and white) all out too… So angry about it! I thought that the white part should be disconnected too, like former iPod models. Be careful, you only have to release the BLACK locking bar! One more photo with a zoom on the battery connector could have been useful… Great guide anyway :-)!
    kabalbuzard - 返信
    Hello! Trying to identify the problem on my Ipod. I think I'm not qualified to open it and do the fixing. Do you know a shop or someone in Paris that would try it? Apple says they are not qualified anymore.
    Thanks in advance!
    Baudu Camille - 返信
    OK, you have to be really careful with this step! If you pry too hard, the little plastic clamp that holds the cable will come up too far and break, and then you are ****ed. It only needs to be raised millimeter or two, but at first, it doesn't move at aIl, so it is easy to pry upwards too hard. I have found that using angled tweezers while VERY GENTLY prying upwards on both sides works best. But still, BE VERY CAREFUL AND GENTLE! It's also easy not to even know that it is up all the way! So every now and then try gently lifting the ribbon cable to see if it is already released.
  19. iPod Classicのディスプレイの交換: 手順 19、 1の画像 1
    • オレンジ色のヘッドホンジャックケーブルにストレスを与えないよう注意しながら、iPodの横にリアパネルを置きます。
  20. iPod Classicのディスプレイの交換: 手順 20、 1の画像 1
    • ハードドライブを片手で持ち上げて、下にあるヘッドフォンジャックのリボンにアクセスできるようにします。
    • ヘッドホンジャックのリボンを固定しているプラスチックのタブをスパジャーでこじ開けます。タブを90度上に回転させ、リボンケーブルを外します。
    • オレンジ色のヘッドフォンジャックリボンをスライドさせて、コネクタから外します。
    • これでリアパネルがiPodから外れました。
    I broke off the plastic tab I lost it any suggestions. How could I replace the plastic tab?
    Fabio a - 返信
  21. iPod Classicのディスプレイの交換: 手順 21、 1の画像 1
    • さて、iPod Classicの内部コンポーネントを解放することによって生じたダメージを修理しましょう!下部ケースのメタル製クリップの少なくとも一つは上向きに曲がっている可能性が高いです。これらのクリップは、リアパネルに再度取り付けるために、全て下向きにしなければなりません。
  22. iPod Classicのディスプレイの交換: 手順 22、 1の画像 1
    • メタルスパジャーの平面側先端を使って、リアパネルから細いメタルレールを裂かないように注意しながら、クリップを押し下げます。
    • ヘッドホンジャックを破損しないように注意しながら、クリップを整形します。
  23. iPod Classicのディスプレイの交換: 手順 23、 1の画像 1
    • クリーンで硬いデスク上で、リアパネルを横にします。慎重に、しっかりと押し込みながら、外縁全体を元の位置に整形します。
    • 側面を直線に保つためには、この作業を複数回行う必要があるかもしれません。フロントパネルを再装着すると、リアパネルが正しい位置に戻されるので、ケースの端が少し内側に押し込まれすぎている方が良いでしょう。
    • リアパネルが元の状態に戻ったので、次はiPodの修理に移りましょう
  24. iPod Classicのディスプレイの交換: 手順 24、 1の画像 1
    • フレームワークからハードドライブを回転させて外し、コネクタが上向きになるように置きます。
    • スパッジャーを使って、オレンジ色のハードドライブリボンを固定しているプラスチック製タブを跳ね上げます。リボンケーブルを解放しながら、タブを90度上向きに回転させます。
    To be clear, the plastic tab to be flipped up is the SMALL BLACK piece shown vertically in the photo above. The spudger is pointing directly to it. The tab flips TOWARDS the ribbon. While the picture is correct, this wasn’t obvious to me.
    Linda and Brian Henning - 返信
    Thanks for the feedback! I will adjust the wording to clarify this.
    Arthur Shi -
  25. iPod Classicのディスプレイの交換: 手順 25、 1の画像 1
    • オレンジ色のハードドライブリボンケーブルをスライドして、コネクタから直接取り出します。
    • iPodのハードドライブを交換する際に、ゴム製のマウントブラケットとフォームパッドが付属していない場合は、これらのパーツを古いドライブから交換用のドライブに移植してください。
  26. iPod Classicのディスプレイの交換, フロントパネル: 手順 26、 1の画像 1
    • フロントパネルをメタル製フレームワークに固定しているプラスネジを3本外します。
  27. iPod Classicのディスプレイの交換: 手順 27、 1の画像 1
    • iPodを180度回転させ、フロントパネルを反対側のメタル製フレームワークに固定しているプラスネジを3本外します。
  28. iPod Classicのディスプレイの交換: 手順 28、 1の画像 1
    • iPod端付近に注意深く手を進め、グレーのメタル製フレームワークからフロントパネルを離します。
    • 2つのコンポーネントを同時に固定している緩い接着剤があれば、わずかに抵抗を感じるかもしれません。
    I would suggest prying with a tool on one of the lips that holds the front place on, but do NOT pry on one near the LCD screen or you may damage the screen. Also, don't forget there is an extra small latch on the top of the LCD that has to be loosened too.
    iTronics Repair - 返信
    I pressed gently on the click wheel on the play botton side first to help unlock the glue. Keep away from the screen side best you can.
    Stephen Sherry - 返信
    After reading all your warnings and how risky it is to damage my IPOD I don’t dare to replace the display which got out of light and I no longer see the text. I planned to send for a new but it seems like the possibility to succeed without damaging the IPOD is less than succeeding. It is really a pity since I love it snd have so much good music saved to it. I usually fix my damaged apparatus but this seems more orf ess impossible after reading the text. I am really sad/devastated!! :
    JaneGBG - 返信
  29. iPod Classicのディスプレイの交換: 手順 29、 1の画像 1
    • フロントパネルから(付属のスクリーン、ロジックボードとクリックホイールを含む)フレームワークを持ち上げて外します。
    • フロントパネルのフレイムワークを再度取り付ける前にクリックホイールボタンが所定の位置にあるか確認してください。
  30. iPod Classicのディスプレイの交換: 手順 30、 1の画像 1
    • これで、iPodからフロントパネルが解放されます。
  31. iPod Classicのディスプレイの交換, ディスプレイ: 手順 31、 1の画像 1
    • スパッジャーを使って、オレンジ色のディスプレイリボンを固定しているプラスチック製タブを跳ね上げます。リボンケーブルを解放しながら、ディスプレイ側にタブを90度上向きに回転させます。
  32. iPod Classicのディスプレイの交換: 手順 32、 1の画像 1
    • コネクタからオレンジ色のディスプレイリボンケーブルをまっすぐスライドして、取り出します。
  33. iPod Classicのディスプレイの交換: 手順 33、 1の画像 1
    • フレームワークアセンブリを持ち上げ、フレームワークアセンブリからディスプレイとLCDメタル製バックプレートをスライドして、取り出します。
  34. iPod Classicのディスプレイの交換: 手順 34、 1の画像 1
    • ディスプレイからLCDメタル製バックプレートを持ち上げて外します。
    • ディスプレイが残ります。
    Ihave a proble, the display is white when i tourn on.
    Help me plz
    Guillermo - 返信
    thank you for showing us it realy helps
    Gustavo Sebwenna - 返信
    Hi, I need to replace my LCD (on my IPOD CLASSIC, 160 GB) but when I see that it is classified as a “VERY DIFFICULT” operation I do get scared. I am not a complete novice (I do exchange computer parts and mend electrical lamps, exchange the electrical parts e t c) but I am scared not to be able to get the IPOD together again after removing the disk e t c. You don’t describe the reassembling steps, how the LCD is exchanged, the disk put back in place e t c. When you do something the first stome you can’’t get info enough. I would like to see more steps after step 34. Until then, the info is superb! :)
    janeossowicki - 返信
    Hi janeossowicki,
    i did change my ipod screen by my self, i was afraid at the begainig , but its okay.
    i filmed the change steps and upload it to youtube to help others.
    you may see the videovia this link :
    https://youtu.be/ALIUMsW044c
    am sorry that i speak arabic in the video but you still can see and know how.
    good luck
    mohamed.alihassan - 返信
    The display panel is very delicate because it uses aluminum foil as the back reflector (for thinness). If you press too hard on the face or twist the frame even slightly, you can permanently damage the display. Ask me how I know. Be very careful at this step.
    floobydust - 返信
終わりに
ケースを閉じる前に、デバイスが正しく機能するか必ずテストしてください。
デバイスを再度組み立てるには、この説明書の逆の順番で組み立ててください。
101 の人々がこのガイドを完成させました。
以下の翻訳者の皆さんにお礼を申し上げます:
en jp
100%
railgunさんは世界中で修理する私たちを助けてくれています! あなたも貢献してみませんか?
翻訳を始める ›
作成者
4人の作成者と共同で作成されました。
iRobot
メンバー登録日: 09/24/09
1 ポイント
636のガイドは作成済み
8 件のコメント
i have the same problem please someone tell me what went wrong
scutch - 返信
If you damage the LCD FPC, do not throw away! I can replace it. The part is not sold so I have to rely on my iPod salvage yard! If you have a classic dead board, I will pay $15 for the board. THe board is used for salvage purposes. If you need the LCD FPC, Battery FPC, hard drive FPC replaced, headphone jack FPC replaced, email me at zfixit.com. I can repair these parts but again, parts are not sold. iPod has to have been working before! No dead iPods that you bought on eBay or craigslist .. fee will still apply! You can check out my contact pages at bustedApple.com and zfixit.com and contact me through there! Price to replace any FPC is $45 + shipping shipping + tax if you reside in Texas. $25 labor fee applies if my work does not bring back to life as it should or the full $45 ++ fee if successful. I can replace the part but other issues with iPod are beyond my control .. so be sure you are original owner with 1st hand knowledge as to the working state prior to FPC damage!
MANUEL ZAMORA - 返信
The 6/7th Gen iPod Classic is very hard to open without damaging the chrome back or clips... You may ruin your device. The ifixit tutorial is not the best, I can open in exactly 30 seconds .. their method seems to take an eternity! If you are lucky, you may succeed but really, these devices should be opened by seasoned professionals. Small price to pay so that you have a working iPod after the repair!
MANUEL ZAMORA - 返信
hi how can i replace the lil black bit that holds the screen when connected i got spare off old board but cant seem to fit it pls help email me
nike17yr10 - 返信
Before opening my iPod for the second time, I purchased a back cover. very good idea and it is not expensive saves me a lot of trouble getting the cover back because i ruined the clips. I had to transfer the battery, the jack and the switch and the little black frame for the usb cable. The rest went well. Thanks
Jean Synette - 返信
Instructions guided me to a fine fix of my screen. I had little trouble in separating the front and rear panels. Interestingly, my unit was missing the LCD metal backplate shown in the directions. But all works well now, thanks.
Fred Turoff - 返信
Is it possible to test a replacement screen for dead pixels before installing it? Thank you,
daniel - 返信
Sehr gut beschrieben, vielen Dank. Mein Ipod Classic hat jetzt ein 2. Leben.
Court Regulator - 返信
コメントを追加
統計データ:
過去 24時間: 25
過去 7 日: 151
過去 30 日: 658
今までの合計 156,672
