はじめに
This guide shows how to remove the click wheel button from an iPod Video.
必要な工具と部品
Insert the iPod opening tool into the left side of the iPod, with the edge of the tool pointing towards the metal back.
A small guitar pick can be extremely helpful in opening the iPod. Simply insert it and slide the pick around the case to free the clips to streamline the process.
Gently enlarge the existing crevice by wiggling the iPod opening tool and moving it to the left.
Continue doing so until the entire side of the iPod is loose.
You can then insert an iPod opening tool to the right of the Hold button. Be very careful while inserting the tool, as the display is very fragile.
Gently glide the iPod opening tool on the top of the display, making sure to free the retaining clips.
The other sides of the iPod should now easily come loose. If they do not, use iPod opening tools on the right side of the iPod in the same way as on the left side of the iPod.
Separate the front of the iPod from the back about an inch (or a couple of centimeters).
Use angled tweezers or an iPod opening tool to slide up the brown connector latch, holding the orange battery ribbon cable in place. Make sure you pull from both sides of the latch. You only need to lift the brown connector latch up about 1-2mm to free the cable. Do not lift more or remove the latch, or you might pull the white connector with it!
Remove the cable from the connector.
Use a small iPod opening tool to release the black hinge holding the hard drive ribbon cable. The tab will rotate up 90 degrees towards the logic board, releasing the ribbon cable.
Use your forefinger to hold the ribbon cable in place; disconnect the drive from the ribbon cable.
Remove the three black Phillips screws securing the front panel to the metal framework.
Rotate the iPod laterally 180 degrees and remove the three black Phillips screws securing the front panel to the metal framework on the other side.
Gently turn the iPod over to the other side. The click wheel button can now be removed from the rest of the iPod.
89 の人々がこのガイドを完成させました。
7 件のコメント
thanks i know my ipod is old but if you can buy replacement parts shoot im gonna keep it .
Great guide! I had a “stuck” click wheel button, but taking it apart, I was able to find out that the tiny soft pad underneath the click wheel button plastic was simply off-center. All fixed!
I had thesame problem like you,and i also got mine fixed.
Same here! That was a cheap repair!
