メインコンテンツにスキップ
iPod 4th Generation or Photo Hard Drive Cable Replacement
必要な工具と部品
  1. iPod 4th Generation or Photo Hard Drive Cable Replacement, Rear Panel: 手順 1、 1の画像 1
    • Before opening your iPod, ensure that the hold switch is in the locked position. The orange bar should be visible, indicating hold is active.
  2. iPod 4th Generation or Photo Hard Drive Cable Replacement: 手順 2、 3の画像 1 iPod 4th Generation or Photo Hard Drive Cable Replacement: 手順 2、 3の画像 2 iPod 4th Generation or Photo Hard Drive Cable Replacement: 手順 2、 3の画像 3
    • Insert an opening pick as far as possible into the seam between the plastic front and the metal rear panel, on the right edge of the iPod.
    • You may need to rock the pick back and forth to slide it in farther.
    • Use the opening pick to pry up against the plastic front panel and release five retaining tabs (seen in the third photo).
    • Slide the pick along the edge of the iPod and continue prying to release the rest of the retaining tabs.
    • After all five tabs along the right side are free, the case should easily open.
  3. iPod 4th Generation or Photo Hard Drive Cable Replacement: 手順 3、 1の画像 1
    • The iPod case is now open, but don't separate the two halves just yet. There is still an orange ribbon cable connecting the headphone jack to the logic board.
    • Open the case like a book with the dock connector edge at the top, and lay the rear panel next to the front half of the iPod.
  4. iPod 4th Generation or Photo Hard Drive Cable Replacement: 手順 4、 1の画像 1
    • Use a plastic tool or your fingernails to carefully disconnect the orange headphone jack cable. Be sure to pull straight up on the connector, not the cable itself.
    • This ribbon cable is very fragile. If you are replacing the battery, you can choose to skip this step and keep the headphone jack connected to the motherboard. Prop and tape the rear case against a box to keep it in place. Be very careful not to strain the fragile headphone jack cable as you work.
  5. iPod 4th Generation or Photo Hard Drive Cable Replacement, Hard Drive: 手順 5、 1の画像 1
    • Grasp the hard drive with one hand and carefully disconnect the orange ribbon cable from the hard drive using your other hand.
    • If the cable doesn't come free easily, it may be helpful to gently wiggle the cable from side to side.
  6. iPod 4th Generation or Photo Hard Drive Cable Replacement, Hard Drive Cable: 手順 6、 1の画像 1
    • Peel up the black adhesive strip covering the hard drive ribbon cable.
  7. iPod 4th Generation or Photo Hard Drive Cable Replacement: 手順 7、 1の画像 1
    • Use the tip of your finger or a spudger to carefully flip up the black connector securing the hard drive cable to the logic board. Note that the black retaining clip flips 90 degrees toward vertical, in the direction of the cable.
  8. iPod 4th Generation or Photo Hard Drive Cable Replacement: 手順 8、 1の画像 1
    • Pull the orange hard drive cable directly out of its connector.
終わりに
8 の人々がこのガイドを完成させました。
作成者
3人の作成者と共同で作成されました。
iRobot
メンバー登録日: 09/24/09
1 ポイント
636のガイドは作成済み
3 件のコメント
My ipod 4th gen does not have the little flap on the cable/logic board. Any ideas how to re-attach?
nick - 返信
Pic 7. whats the second ribbon cable terminal for? I broke ribbon clamping mechanism, is it possible to fix that?
Johny Doc - 返信
I think I broke something, I suppose the clamping mechanism. I mean the black flap is open 90 degrees but when I close it it does not clamp to anything
Ema -
コメントを追加
統計データ:
過去 24時間: 5
過去 7 日: 12
過去 30 日: 56
今までの合計 20,590
