はじめに
Replace a cracked or faulty display.
Before opening your iPod, ensure that the hold switch is in the locked position.
  • Before opening your iPod, ensure that the hold switch is in the locked position.
コメントを追加する
Opening the iPod can be challenging. Don't get discouraged if it takes a few tries before the iPod is opened.
  • Opening the iPod can be challenging. Don't get discouraged if it takes a few tries before the iPod is opened.
  • Insert a plastic iPod opening tool in the seam between the white plastic front and metal back of the iPod. Once you've inserted the tool, run it along the seam to free the five tabs holding the iPod together.
コメントを追加する
Continue to run the opening tool along the side of the case until all five tabs have been released.
  • Continue to run the opening tool along the side of the case until all five tabs have been released.
コメントを追加する
Work around the corner of the iPod and release the two tabs holding the iPod together near the dock connector.
  • Work around the corner of the iPod and release the two tabs holding the iPod together near the dock connector.
コメントを追加する
Free the five tabs holding the iPod together on the other side. You may be able to free the tabs by gently wiggling the front panel of the iPod.
  • Free the five tabs holding the iPod together on the other side. You may be able to free the tabs by gently wiggling the front panel of the iPod.
コメントを追加する
Lift the rear panel away from the iPod, making sure it doesn't catch on the headphone jack.
  • Lift the rear panel away from the iPod, making sure it doesn't catch on the headphone jack.
コメントを追加する
Peel up the metallic tape attached to the top of the battery.
  • Peel up the metallic tape attached to the top of the battery.
コメントを追加する
MacBook Battery Fix Kits
Fix Kits Starting at $69.99
Starting at $69.99
Lift the battery up from the hard drive and lay it next the the iPod (it is still connected to the logic board).
  • Lift the battery up from the hard drive and lay it next the the iPod (it is still connected to the logic board).
コメントを追加する
Carefully disconnect the orange ribbon cable from the hard drive.
  • Carefully disconnect the orange ribbon cable from the hard drive.
  • If the cable doesn't come free easily, it may be helpful to gently wiggle the cable from side to side.
  • Lift the hard drive out of the iPod.
コメントを追加する
For the following step, you only need to move the locking bar about 2 mm. Pushing too hard or too far will damage the connector.
  • For the following step, you only need to move the locking bar about 2 mm. Pushing too hard or too far will damage the connector.
  • Loosen the connector by pulling the brown locking bar toward the hard drive cable using the tips of your fingers.
コメントを追加する
Slide the hard drive cable out of its connector.
  • Slide the hard drive cable out of its connector.
コメントを追加する
Lift the blue hard drive mounting bracket out of the iPod.
  • Lift the blue hard drive mounting bracket out of the iPod.
コメントを追加する
Carefully disconnect the white battery connector from the logic board. Be sure to pull only on the connector itself and not on the cables.
  • Carefully disconnect the white battery connector from the logic board. Be sure to pull only on the connector itself and not on the cables.
コメントを追加する
Like the hard drive connector, for the following step, you only need to move the connector about 2 mm. Pushing too hard or too far will damage the connector.
  • Like the hard drive connector, for the following step, you only need to move the connector about 2 mm. Pushing too hard or too far will damage the connector.
  • Loosen the touch wheel connector by pulling the brown locking bar toward the side of the iPod using the tips of your fingers.
コメントを追加する
Remove the 8 T6 Torx screws from the logic board.
  • Remove the 8 T6 Torx screws from the logic board.
コメントを追加する
Lift the logic board up enough to disconnect the orange touch wheel cable.
  • Lift the logic board up enough to disconnect the orange touch wheel cable.
  • Lift the logic board out of the iPod.
コメントを追加する
Note the location of the four white plastic tabs securing the display to the logic board. These tabs must be released before the display can be removed.
  • Note the location of the four white plastic tabs securing the display to the logic board. These tabs must be released before the display can be removed.
コメントを追加する
Use a spudger or your finger to free the four white plastic tabs indicated in the previous picture.
  • Use a spudger or your finger to free the four white plastic tabs indicated in the previous picture.
コメントを追加する
Use a spudger to carefully disconnect the display ribbon cable from beneath the scroll wheel.
  • Use a spudger to carefully disconnect the display ribbon cable from beneath the scroll wheel.
  • Lift the display off the logic board.
コメントを追加する
まとめ
ある他の人がこのガイドを完成しました。
iRobot
メンバー登録日: 2009年09月24日
1 ポイント
745のガイドは作成済み
コメントを追加する
統計データを表示:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 8
今までの合計 6,379
